Yeah, all of these had the same single package bios. So you do the official downgrade of your Z840 with the jumper, and would have a proper 1.62 on your workstation.
Then we can establish if modding this 1.62 works, and take it from there.
@68k-dude@karfel and other people who can help me
hi everyone.
my English is not very good. let me explain it briefly.
my motherboard is X99-E WS/USB3.1 , Graphic Card is Nvidia RTX A400,i have modified the BIOS, but the resizable bar failed to open successfully
My Bios file in here .
i get three files ,i see a " fwupdate.bin " ,so first can i flash fwupdate.bin to ME firmware ,second i need to flash bios use " NvStrap3.CAP " or " NvStrap4.CAP " ?
Thank you, I understand now. I just used the file “X99-E-WS-USB31-SUS-4001-NvStrap4. cap” and added the component “ReBarDex. ffs” inside it, successfully opening the Resizeable Bar.
Thank you. I don’t know how to thank you, this question has been bothering me for a week.
Hi, first of all thanks to all people here sharing their kwoledge, it turns in a very helpfull experience.
Now proceed with the matter:
My system
CPU Ryzen 5 2600
MB Gigabyte B450M-K rev2.0
Bios FDd
GPU Intel Arc A380
GPUz Resizable BAR status window informs all is Ok (YES) but the support from MB (NO)
The BIOS seems have ReBAR support available but it is not possible check to AUTO in the UEFI because the option is not appearing, i.e. 4G decoded is appearing and it is checked YES.
I have tried to use the guide
Confirming the existence for the ReBAR option in the BIOS, even using the Grub tool explained in the guide, I have forced the parameter ReBAR to AUTO without success.
I think the problem is the CPU type and, could be, the bios is not only looking for the parameter in AUTO but also something more still blocking.
I have tried also to modify the BIOS including the ReBAR module, but the bios update tool rejected the MOD indicating something like INVALID BIOS.
Question: In this type of BIOS where the ReBAR support seems to be included would be necessary add the ReBAR module? or could be better try to use the built-in module, overriding the “protections”?
Hello guys, I have been trying this guide from xCuri0 to mod BIOS for my Lenovo M720s.
Problem when I convert bin file to .txt. Inside the txt file there is nothing that mentions “4G Decod” or “Above 4G”. How come uefi tool finds text within bios but then when I extract and convert that from powershell its no where to be found?
Greetings friends, modders and computer enthusiasts.
I need to activate the 4G bar resizable on my old Z77 Extrem6/TB4 motherboard… I have it equipped with an Intel i7 3770K and 32gb of ram along with an RX580 8gb 2048sp. The thing is that I don’t know how to do it, I’ve downloaded all the programs but I have no idea how to do any of this. I’ve been asking for help on several occasions but the more I read the more my head gets tangled and the less I understand, and the truth is I don’t feel capable enough to do this since I don’t have anyone who can explain this to me in detail to know if I’m doing well or not, and I saw a guide but I don’t know if this is true for all motherboards. I’m going to leave the BIOS that I’m currently using on my PC already modified to boot via PCIe with an NVMe M.2 adapter in case someone can help me and make this modification to the BIOS that I leave below. TB4.rar (4.5 MB)
Hi @Greenapp did you manage to flash the Z97AU31.zip rebar successfully, and have it work on your Z97-a mobo?
re: ASUS Z97-A rebar mod @mhi00002000
Hi, did you manage to flash a bios with rebar that works on your mobo? I’m looking for a version of the rebar modded Z97-A that works for rebar.
Hi, If anyone has managed this or knows anyone who has achieved this successfully on a ASRock B450 Pro4 Board please get back to me via reply here or DM.
@Electron-PSO
As you say, I post my request here again.
Hi, I´m 55 years old, my english is very bad. I don´t have the money for a new pc, so I bought a Intel Arc B580. But my mainboard bios
doesn´t have the “resizeable bar funktion” it´s an Asus Maximus Code IX with a intel z270 chipset. The last bios is from 2021 Version 1501.
Can anyone help me to creat a modded bios with resizeable bar funktion ?
Hi. I checked around and there are only two posts that mention a similar motherboard and none of them is of any help. I have a i5 7600 and an RX 580 8GB. I tried to follow this guide
in order to mod my bios (F26a) so it’d allow ReBar to work. I failed because my programming knowledge is very limited. I thought I’d seek help here. I am terribly sorry for the inconvenience.
TL;DR: does anyone have a modded bios that has Rebar enabled?
