Replacing AHCI PCI ROM module
Yes, that is what I would try to do.
Same error-message after installation of the drivers (HDMI-audio driver). But now - with deactivated onboard-graphic - there is a difference:
. The driver seems to be working. I can choose the full resolution (1920*1200) and the monitor is reconized .
Thanks a lot!
By the way, can you evaluate the following graphic please? Is there a problem with my HDD
That is fine now.
Yes, there may be a problem. I recommend to do a test by using the Samsung HDD diagnostic tool named "ES Tool" (>LINK<).
Many Thanks for your help!!!
