[Request] 2021 AMD Legion 7 16ACHg6 - Advanced Options Unlock
Edit: Worked it out on my own and unlocked it successfully.
Hello,
Rodpad - LegionFanControl developer here.
Please could I request that my 2021 AMD Ryzen Legion 7 16ACHg6 BIOS is modified to enable Advanced Options.
I’m hoping this might help me find additional fan related settings that could be incorporated into LegionFanControl for all users on a standard BIOS, via Embedded Controller manipulation.
@Lost_N_BIOS - I have been referred to you from the Legion Series Discord. Would you possibly be able to help me out? I will of course send you a donation for your time.
I’ve attached my BIOS to this post.
Many thanks,
Rodpad
Edit by Fernando: Thread title shortened
Is there possibility to activate RAID in Advanced Options on Legion 7 16ACHg6?
There is an option for it yes.
How did you unlocked it please? Reverse engineer, secret key combo?
I dumped my BIOS, modified it then flashed it back.
I’m unable to post links here so I can’t share the guides sadly.
Hello, please can you help me unlock Sata mode selection (raid mode) for legion 7 16achg6 . My bios ver. GKEC50WW
Sent some screens for gdrive but cant post.
I can donate something for help.
I need your BIOS dump.
Hello, i copy bios with Universal BIOS Backup ToolKit 2.0 (16mb). where i can sent it? give me email or something.
Можно на нашем)
I hope you understand what you involved into.
[GUIDE] Flash BIOS with CH341A programmer
www.sendspace.com can deliver your files.
I not have programmer and cant use it. I understand about chance receive stone and sent NB to RMA for fix,using programmer.
GKEC50WW
Upload bios to sendspace, link code qdg94c
at post have error : Your posts contains to many links. A maximum of links is allowed.
It is also required to install modified BIOSes for devices with AMD processors.
If i can flash modified bios without programmer its ok. Using dos or win.
Actually, It would be more than OK, but that’s impossible.
Oh, now i understand.
Thnks for your explanations, i just waste your time
Hello can some 1 upload the bin file from a dump? thnx a lot
