First of all, thank you for this useful forum. Using the information on this site I was able to add NVME support to my server.
The motherboard is a BCM MX81H industrial motherboard and it uses a fairly standard AMI Aptio v4 UEFI BIOS. I would like to add menu options that allow me to enable SATA hot swap on all 4 SATA ports. The chipset should support this feature, it just isn’t exposed in the BIOS menu.
Any help would be appreciated. I have attached both the OEM BIOS as well as my version modified with NVME support.
Thank you, this mod added the hot swap settings I needed as well as many additional others. I have attached the screenshots you requested. I don’t believe anything has been added to those menus compared to the previous BIOS
I tried the new mod and this one seemed to unlock the extra options under the chipset and power tab. It also enabled the extra settings under RTC that you mentioned
