[REQUEST] Asrock B450 Gaming K4 - Higher auto-oc range options
Hi,
I recently crossflashed a bricked B350 Gaming K4 to B450 Gaming K4 and replaced my old MSI B350 Pro-VDH with it. Its running as it should (other than Vcore offset not doing anything… That would be nice) but under AMD overclocking the Auto-OC option is limited to +200Mhz which is AMD standard as far as I have understood. However, my old MSI board had actually a different dropdown menu for this which allowed values all the way up to +500Mhz, making single core speeds push up to 4.5Ghz on my ryzen 5 3600 with default voltages! Now this is limited to 4.4Ghz and on top of that I cant even use negative offset to get lower temps/wattage for this reduced speed. Could the range be extended on this one, too?
REQUEST:
Increase the range of Auto-OC selection from +200Mhz to at least +300Mhz
