Hi.
I did purchase a TMP2-S Module for my motherboard and i can not get it working.
Bios Version is the latest which is 2.10. Trusted function is activated in bios but the module is not recognized. I also checked if it is plugged in correct, and the pins do match.
I guess the bios supports only a lower TPM version? It would be super nice if somebody could update the bios because i have limited (none) experience in bios modding.
Thanks!
The latest bios version can be downloaded here:
https://download.asrock.com/BIOS/1150/H97%20Pro4(2.10)ROM.zip
You bought the wrong module, it should be the TPM-S v1.2.
The bios lacks a lot of TPM2.0 specs implemented, i would not expect that some one can mod this for you.
Try to get a custom bios from ASR tech support.
ASRock > TPM Module
EDIT: So as you see on that linked page, the user got a file from ASROCK, ask them.
I did find an interesting post at the asrock support page. The technicians from asrock did make an inofficial bios/uefi for the H97M Pro4 version which supports TPM 2.0
Maybe this file is comparable to the non “M” version?
Modified one with TPM2.0 for the M model
https://qasimk.io/media/2018-02-10-H97MP42.10C.zip (from this page TPM2 on ASRock’s H97M Pro4 Motherboard | QasimK )
I did, but they did not reply for a week now.
