Hi, there are solder pads on the board. You can use them to set bifurcation. It’s CFG5 for x8x8 and CFG5 + CFG6 for x8x4x4. It works for me, but it took some time to ring configuration pins and figure out which ones they are.
This is an awesome find! I was about to move up to matx, but with this, I might not have to get a new mobo. Though the lack of 3pin fan control still bugs me.
Yes its simple as that. Solder iron and short it. Depens what configuration you need short one or both. Three pin control might be suppresd by pcb in the middle solution, for sure there is one on aliexpress. Please reply if worked for you too
Did you turn off CSM legacy and turn on bove 4k decoding aswell? And you need to have with UFEI only installed system, GPT partition on disk is please to have.
