Can you unlock it in the F64 file please thanks in advance
Please Kitten ![]()
F64 on Mega.
ABSOLUT perfect this is what works well for me THANKS A LOT!!!
Better as expected Kitten, i have now every option i need Dynamic vcore dvid and i also have my CPU negative core optimization THANKS you ROCK thank you sooooooo much you made my whole day better !
Hi! I tried your bios with 5700x, the settings CPU Vcore did not appear. Can this be fixed?
Where in the bios did you expect it to appear?
MistH only for the X3D Processors are options hidden or removed also youll find the cpu vcore into the Amd Overclock menu
@Sweet_Kitten any chance you can unlock the same option for my ASRock B550 Phantom Gaming ITX
Best for the 3.40 Bios this would be awesome
https://pg.asrock.com/mb/AMD/B550%20Phantom%20Gaming-ITXax/index.de.asp#BIOS
same options like the x470
Greetings and btw you got discord or something like that ?
Hi. I got ill this week, so I didn’t bother logging in on the forum.
My discord name is @bobmanextra, leave a message if you need help with your asrock board.
Got the same CPU and Motherboard.
Installed the provided F64.
Where do you find the CPU negative core optimization? Not seeing it ![]()
EDIT: PBOTuner2 does the trick. -30 on all cores and all stable at 4,5 Ghz.
