Request for Z370 AORUS Ultra Gaming
hi guys! can anybody mod the bios for this board? for example disabled hpet and some new driver? will be perfect
@vagenrider - I can disable HPET for you, what else do you want updated?
thank you so much for the super fast response, anything else you want will be perfect.i trust your knowledge
https://www.mediafire.com/file/1dlkcvrhm…_f15_n.zip/file
@vagenrider - You’re welcome! I don’t want anything, it’s not my board You have to tell me what you want done
Also, are you sure you want F15n modified and not latest F16a?
yes you’re right :smiley: i tell you about the f15 in terms of stability,but its fine if no problems with the f16a! i have an 8700k and i was thinking about disabled hpet,intel rst and the microcodes for the cpu :slight_smile:
I don’t have this board, nor follow threads about it, so I can’t say what BIOS is good, or if there is issues with F16a etc. I only mentioned in case you didn’t know it was posted.
I can do whichever BIOS version you want, and we can wait and you test F16a stock for a while if you want too, then decide, or pick now without testing F16a
Yes, I can disable HPET for you, update all CPU microcodes, and update RST (this only matters if you use RAID, or onboard NVME slots)
about the rst if helps only on raid,then leave it unthouched because im not using…so only disabled hpet and microcodes its fine,im on f16a for about a week without problems so i believe you can mod this :slight_smile:
goodevening! you have any news?
@vagenrider - Here you go - http://s000.tinyupload.com/index.php?fil…588837713255842
1. HARD Disable HPET (ie Change Default = Disabled in all areas >> Setup, NVRAM x2 + PEI, AMITSE/SD)
2. Update all CPU microcodes to latest version as of 7/15/2020
Flash via Qflash, clear CMOS once done, enter BIOS, load optimized defaults, then save/exit, reboot back to BIOS and make all changes you need before loading windows
