[Request] Galax B350M hidden menu unlock (read before skipping)
I’ll fix that later.
And wdym ftpm is gone? Like no device?
Yeah, this one’s not your fault. This motherboard always showed no device there. Unfortunately I don’t remember how I fixed it. That’s on me.
Yeah no security device
I think I fixed it. Let me know if so. You may download the file.
One small question. Did you flash bios according to README? I’m surprised flashrom worked flawlessly.
I ended up flashing it with my ch341a
So software flash did not work or you have not tried it?
Im asking for future visitors.
My dumb brain did not consider that I’d have to set boot filter to allow legacy boot
I’m suddenly having some trouble with my ch341a so I’ll try that now
Is there any way to force flash with afuefi or afuwin? My mobo does not want to boot with anything other than .efi files even though secure boot is turned off and boot filter allows both uefi and legacy boot
I don’t think it’s possible.
welp, i think my soic8 clip for the ch341a is done for because it just won’t detect the bios chip anymore. I found out that I can force flash with a specific version of afuefi so I’ll try that now
I’ve run out of options and given up for tonight, will try tomorrow
