I accidentally corrupted my original AMI bios file without backup and lucky enough the seller for my motherboard provided me another set of bios files, which i can use for booting up successfully, but unable to get my ethernet LAN to function, apparently there are two different LAN chipset used for the same motherboard, and the seller only has the I219 on hand, not the I211 which I have. I am hoping to find guidance on how to make the necessary changes to this bios file in order for my Ethernet LAN to work again. My motherboard has 2 bios chips, bios files is dump from each bios chip using programmer, one bios chip contains only ME firmware and the other contains the rest. @Sweet_Kitten
c24h4-am (1).zip (4.87 MB)
c24h4-am2 (2).zip (4.51 MB)
