Hello, I installed WinXP SP3 Professional 32-bit on my HP Elitebook 840 G1 (Intel i7-4600U CPU @2.10Ghz), 8GB DDR3 Ram. The only thing I couldn’t install was the graphics Driver. Installing the driver from Snappy Driver causes a blue screen with the error code: *** Stop: 0x00000050 (0xF0002F72, 0x00000008, 0xF0002F72, 0x00000002)
Try installing Driver Max.
Driver Max wants to try to install the same driver which snappy driver recommends. So it caused the same bluescreen error. It’s the Intel Haswell HD graphics - GT1ULT.
I think the only way to solve this is with a modded driver. But I don’t know how to do that and don’t know where I can find one that works with my device.
@Fernando Do you know an solution for this, or is it not possible with this Laptop?
No, I haven’t even tried to install Windows XP onto any of my devices since more than 15 years.
Edit: By the way - I have customized the thread title.
