[Request] Megaware Meganote Suppressed menu entries
Hello. I’m trying to access an “Advanced” hidden menu, but AMIBCP 4.53 only shows the shortened form.
With ifr extractor this shows:
|0x13D52||Main (0x7 from string package 0x0)|
|0x13EE2||Advanced (0x18 from string package 0x0)|
|0x141A5||Security (0x3B from string package 0x0)|
|0x147AE||Boot (0x1C from string package 0x0)|
|0x14A54||Save & Exit (0x4D from string package 0x0)|
|0x14BAE||Main (0x7 from string package 0x0)|
|0x14FB3||Advanced (0x18 from string package 0x0)| (HIDDEN)
|0x1A873||Power (0x3D from string package 0x0)|
|0x1A8EB||Boot (0x1C from string package 0x0)|
|0x1AC93||Security (0x3B from string package 0x0)|
0x14FB9 Form Set: Advanced {0E 24 43 D6 87 EC A4 EB B5 4B A1 E5 3F 3E 36 B2 0D A9 18 00 19 00 00 00 00 00 00 00 00 00 02 00 00 00 94 02}
0x14FDD 	Var Store: [0xF000][E770BB69-BCB4-4D04-9E97-23FF9456FEAC][001][SystemAccess] {24 23 69 BB 70 E7 B4 BC 04 4D 9E 97 23 FF 94 56 FE AC 00 F0 01 00 53 79 73 74 65 6D 41 63 63 65 73 73 00}
0x15000 	Var Store: [0xF013][C811FA38-42C8-4579-A9BB-60E94EDDFB34][065][AMITSESetup] {24 22 38 FA 11 C8 C8 42 79 45 A9 BB 60 E9 4E DD FB 34 13 F0 41 00 41 4D 49 54 53 45 53 65 74 75 70 00}
0x15022 	Var Store: [0x0036][EC87D643-EBA4-4BB5-A1E5-3F3E36B20DA9][002][UsbMassDevNum] {24 24 43 D6 87 EC A4 EB B5 4B A1 E5 3F 3E 36 B2 0D A9 36 00 02 00 55 73 62 4D 61 73 73 44 65 76 4E 75 6D 00}
0x15046 	Var Store: [0x0037][EC87D643-EBA4-4BB5-A1E5-3F3E36B20DA9][015][UsbSupport] {24 21 43 D6 87 EC A4 EB B5 4B A1 E5 3F 3E 36 B2 0D A9 37 00 0F 00 55 73 62 53 75 70 70 6F 72 74 00}
0x15067 	Var Store: [0x0039][560BF58A-1E0D-4D7E-953F-2980A261E031][002][SerialPortsEnabledVar] {24 2C 8A F5 0B 56 0D 1E 7E 4D 95 3F 29 80 A2 61 E0 31 39 00 02 00 53 65 72 69 61 6C 50 6F 72 74 73 45 6E 61 62 6C 65 64 56 61 72 00}
0x15093 	Var Store: [0x0044][D1405D16-7AFC-4695-BB12-41459D3695A2][001][NetworkStackVar] {24 26 16 5D 40 D1 FC 7A 95 46 BB 12 41 45 9D 36 95 A2 44 00 01 00 4E 65 74 77 6F 72 6B 53 74 61 63 6B 56 61 72 00}
0x150B9 	Var Store: [0xF018][EAD039A6-7390-411D-A9DE-E5294B25B897][002][PegaEZFlash] {24 22 A6 39 D0 EA 90 73 1D 41 A9 DE E5 29 4B 25 B8 97 18 F0 02 00 50 65 67 61 45 5A 46 6C 61 73 68 00}
0x150DB 	Var Store: [0x0046][EC87D643-EBA4-4BB5-A1E5-3F3E36B20DA9][019][SetupCpuFeatures] {24 27 43 D6 87 EC A4 EB B5 4B A1 E5 3F 3E 36 B2 0D A9 46 00 13 00 53 65 74 75 70 43 70 75 46 65 61 74 75 72 65 73 00}
0x15102 	Form: Advanced, Form ID: 0x8 {01 06 08 00 18 00}
0x15108 		Subtitle:  {02 04 02 00}
0x1510C 		Subtitle: Legacy OpROM Support {02 04 88 00}
0x15110 		Grayout If: {19 03 00}
0x15113 		Variable Store Select: 0xF000 {25 04 00 F0}
0x15117 		Variable 0x0[1] equals 0x1 {12 07 00 00 01 01 00}
0x1511E 			Variable Store Select: 0x0 {25 04 00 00}
0x15122 			Checkbox: Launch Storage OpROM, Variable: 0x3A[1] {06 0C 3A 00 01 89 00 8A 00 13 00 00}
0x1512E 		End If {18 02}
0x15130 		Subtitle:  {02 04 02 00}
0x15134 		Subtitle:  {02 04 02 00}
0x15138 		Setting: Enable CRID, Variable: 0x215[1] {05 09 15 02 01 97 02 98 02}
0x15141 			Option: Disabled, Value: 0x0 {09 09 8E 00 00 00 13 00 00}
0x1514A 			Option: Enabled, Value: 0x1 {09 09 8D 00 01 00 00 00 00}
0x15153 		End of Options {10 02}
0x15155 		Suppress If: {0A 03 00}
0x15158 		Variable 0x215[1] equals 0x0 {12 07 15 02 01 00 00}
0x1515F 			Setting: ICH CRID Key (Hex), Variable: 0x216[1] {05 09 16 02 01 7E 04 7F 04}
0x15168 				Option: 1D - CRID #1, Value: 0x1D {09 09 80 04 1D 00 00 00 00}
0x15171 				Option: 2D - CRID #2, Value: 0x2D {09 09 81 04 2D 00 13 00 00}
0x1517A 			End of Options {10 02}
0x1517C 			Setting: MCH CRID Key (Hex), Variable: 0x217[1] {05 09 17 02 01 7B 04 7C 04}
0x15185 				Option: 69 - CRID #1, Value: 0x69 {09 09 7D 04 69 00 13 00 00}
0x1518E 			End of Options {10 02}
0x15190 		End If {18 02}
0x15192 		Selectable: PCI Subsystem Settings, Form ID: 0xE {0F 0B 0E 00 25 04 29 04 00 00 00}
0x1519D 		Selectable: ACPI Settings, Form ID: 0x10 {0F 0B 10 00 6D 00 6E 00 00 00 00}
0x151A8 		Selectable: North Bridge Configuration, Form ID: 0x12 {0F 0B 12 00 91 00 92 00 00 00 00}
0x151B3 		Selectable: South Bridge Configuration, Form ID: 0x20 {0F 0B 20 00 1B 02 1C 02 00 00 00}
0x151BE 		Selectable: ME Configuration, Form ID: 0x2F {0F 0B 2F 00 F5 02 F6 02 00 00 00}
0x151C9 		Selectable: Thermal Configuration, Form ID: 0x31 {0F 0B 31 00 18 03 19 03 00 00 00}
0x151D4 		Selectable: USB Configuration, Form ID: 0x38 {0F 0B 38 00 BF 03 C0 03 00 00 00}
0x151DF 		Selectable: Serial Port Console Redirection, Form ID: 0x3A {0F 0B 3A 00 E8 03 E8 03 00 00 00}
0x151EA 		Selectable: Network Stack, Form ID: 0x45 {0F 0B 45 00 21 04 22 04 00 00 00}
0x151F5 		Selectable: CPU Configuration, Form ID: 0x47 {0F 0B 47 00 D9 04 DA 04 00 00 00}
0x15200 	End Form {0B 02}
Motherboard Pegatron - Model H54
Bios.: 08:00:10 Version
American Megatrends
SMBIOS BIOS VERSION - 203.T02
SMBIOS MAJOR VERSION - 2.6
DUMP:
Thanks.
