Hi, sadly none of these cmdlets works (I was trying nearly every single potential “fix” i found or could think of). It just says that the module is either missing or that there is an access error - which i guess comes to the same conclusion).
Maybe the hint of yours could work (with this other option) but i have no clue on how to edit the bios to show hidden options.
BTW: Is it even possible to have an i7 6700k work with the M8E? I’ve read online that the i7 6700k lacks TPM 2.0, while the 6700 without k has it (So far i thought TPM is chipset things). Device Manager is not showing the Security Module.
EDIT: I will send you the error messages for the tpm cmdlets when i’m at home
Unfortunately the setting I mentioned is stored in FD and probably the FD is still write protected even in dsankes modded bios.
1.) I don’t know if flashback will overwrite the FlashDescriptor
2.) I don’t know if the caspule is specific for the complete content, I just changed one bit in FD without modifying the capsule
3.) This might brick the computer (but I think this might be the last setting missing?)
Just changed the one bit that enabled ‘TPM over SPI bus’ in FD in dsankes firmware, you can try to write it with flashback:
EDIT 2
Had a lock at MSIs Z170 board and it’s just the Z170A GAMING PRO where one can choose between dTPM and fTPM, and it’s bios doesn’t have the TPM over SPI bus option enabled.
Hi, i just flashed your file with bios flashback. But it seems that it didnt override flashdescriptor. I did a backup of the bin file before and after the flashing and compared it with fc.exe tool in commandline.
to EDIT 2: I have the dTPM option aswell, i can choose between PPT and dTPM, so far i always used PTT.
Sorry, but you dont have control, you can just read the complete firmware which is good in case of backup, but doesn’t say anything about writing the firmware.
I read the complete thread you linked and checked the ME config for those where it worked- there’s no common factor related to working that could be changed here. I’m sorry, but I think this is relating on bios implementation, maybe some Windows factors, too. Maybe installing Intel ME drivers for your platform again might help in recognizing but I doubt it.
Sorry, but I don’t see anything meanigfull I could do at this point, it’d be just groping around.
