I have this display adapter, I was able to OC it to 1073 Mhz with stock VBIOS, but it artifacts a lot. My VBIOS is attached below. Can someone please mod it to have a bit higher core clock and memory clock, and if possible, unlock voltage control?
Also, If this is not the right forum for posting VBIOS requests, I request the mods to move it to the relevant forum.
GF119.zip (107.2 KB)
You cant expect to “squeeze” a low LOW end gpu card and that usually is made of low LOW cheap components and not getting artifacts or great instability…
Search for FERMI editor and play yourself with it.
EDIT: Sorry i cant, you can try to manually (hex edit) the tables, you’ll have to look for info for it about this on the web.
Yes, I tried Fermi bios editor but it says unsupported device. I also tried Nibitor, but it also says my card is not recognized. Can you recommend any other program? Thanks.
Bumping the search for a tool that recognizes Fermi BIOS for ALL cards… My GTX 460 ISNT recognized by either FBE or Nibitor
Any BIOS gurus able to get this GTX460 BIOS editted? Fermi BIOS editor doesnt recognize,nor does Nibitor.
My card OC rather nicely over the factory OC to 900/1800/2500 with no voltage increases. I’d like to lock that in… and maybe experiment with a little undervolt if someone knows a tool that works?
