[Request] Monster ABRA A5 V15.4 It opens after 20 seconds
Brand : Monster ABRA A5 V15.4
Motherboard : GK5CP5Z MB V.1
Hi. SR40B has been changed. It opens after 20 seconds. I’m probably making a mistake.
CSME System Tools v12 r38 / Open fit / load bios / build settings gen. int. files NO /save x.xml / close fit / decomp (ME Sub Partition 12.0.20.1307_CON_H_BA_PRD_RGN rename) / Open fit / load x.xml / build image.
Also, there are 2 more problems. Can they be fixed with bios?
  1. M2 ssd is not detected, tried with another m2.
  2. The laptop does not turn on when the wifi card is inserted (the wifi card may be faulty)
    Finally, if possible, it gets a bit too hot even in bios. A little performance throttling would be nice.
