Hi. I was looking for the latest bios for this board with the hpet option exposed if someone has it. Link to the current bios https://download.msi.com/bos_exe/mb/7B79vHC.zip
Thanks for the help.
@uiki
Try this mod(re-flash it via m-flash) ,then check whether you could find option HPET under Settings button => Advanced =>Integrated Peripherals
Thank you. I’ll try as soon as I am home.
It’s great~
