Hi,
I come from the SevenForums forum. I was referred to winraid.
I don’t know if it’s the right name, but i think my graphic’s card is Intel UHD Graphics 620.
HWID:
PCI\VEN_8086&DEV_8A56&CC_0300
I appreciate any help
Thank you!
@zenon : Welcome to the Win-RAID Forum!
Which OS are you currently running resp. want to run in the future?
Regards
Dieter (alias Fernando)
P.S.: If applicable, please use the "@nickname1 " option instead of quoting posts.
Hi Fernando
I am currently running Windows 7 x64 bit and would love to run Windows XP on the mobo. There’s a problem though. It just gets stuck at “Setup is starting Windows” after booting to setup via USB. I use the windows xp integral edition image (it has sata drivers)
Best regards
@zenon
I’ve ran into this problem before, in my case it was the XP kernel panicking because of too many CPUs on my threadripper system, I doubt this applies to you though.
@diderius6
what were some of the other causes of XP setup freezing at “Setup is starting Windows”?
Okay, thanks for the informations
We wait for Fernando
Oh, I wanted to know, if you knew any causes , for the freezing of windows xp setup.
@zenon
1. Download graphics driver version 22.20.16.4691 and unpack it by WinRAR.
2. In the folder Graphics rename ki122753.cat to igdlh.cat
3. Unpack my mod in the folder Graphics.
4. Boot Windows 10 in with disabled driver signature enforcement or enable test mode.
5. Install driver as usual: by exe-file or Device Manager.
6. Choose “Install this driver software anyway” when Windows ask.
7. Reboot in normal mode.
8. Make a screenshot of General tab in properties of installed graphics driver.
9. Open Event Viewer and go to Windows Logs->Application
10. Make a screenshot of the last event with a source is Windows Error Reporting and a name is LiveKernelEvent
Thank you
@infuscomus
When XP hangs during setup at this place "Windows starts"
there can be 2 reasons:
1.) A BSOD, mostly about acpi.sys, so use other acpi.sys.
2.) A problem with the geometry of the harddisk.
This problem can be solved, when you use RMPrebUSB 2.1.739 for formatting the disk
Dietmar
@diderius6
Thanks.
If I recall correctly, you said using hard disks larger than 2TB can also cause this problem?
@zenon
Do you have any hard disks larger than 2TB?
Thank you! I’ll try your solutions.
Nope. I do only have an HDD of 1TB.
