Hi, after flashing bios using CH341A programmer, Model name, S/N and MTM is INVALID in bios and vantage is INVALID. I was wondering if someone could please help me with this as i cant do it myself. It would be very much appreciated. I will leave a dump of the BIOS file i used with the programmer aswell as the numbers
Model name: 81SX
S/N: PF1YG5G4
MTM: 81SX002HMX
Every piece of help is appreciated
Link to bios file: https:// drive.google.com/file/d/1poNmPq1WRFl0202Vvhktbct-0fKyvQBP/view
Hi friend, could i ask you why you used the CH341a and if you made a Dump before write new file into ? have you all system data you lost , UUID, Serial, etc ?
To recover your Firmware we need to get all pc informations, so it would be usefull ot get a Bios Menu Information Tab photo to see actual info state and the
labels present on pc with all elements (UUID, Serial, Model, Mac, etc) photos too or a txt file with them into.
Let me know
Regards
Thank you for answer. Unfortunately i did not get to dump my ¨at the time working¨ bios as i was downgrading it for undervolting support. But i have a dump file of the bios i read that was broken if that is to any help? That is why i used the CH341A programmer, and it worked fine, but it lost the numbers. Anyways i will upload photos of both bios and the sticker on the back. Thanks in advance
Even the dump of the bricked bios can be of help, often the bios areas with machine specific information are untouched, so if it’s a valid dump it might be easier to copy/ paste these areas.
I am not too sure if it’s valid but it checked out 4 times on md5 checksum. I will post link to the dump.
https:// drive.google.com/file/d/1AZStOakWpLmtA63CWeydvEq-vbwyQI9m/view?usp=sharing
Sorry, but all "FF". One might check structure with UEFIToolNE, and have a look into the file with a hex-editor, if content could be important.
