I cannot attach files at this time however I have my modified bios as well as bios dump, I used intels FPT to dump and tried to flash but get error saying registers are write protected.
I’d like to know what are my options and if I’m doing the right thing with FPT.
I tried using ru.efi but the varstore page is empty, it has a single entry with a blank name and I don’t see CpuSetup or any other stores.
I also tried the modified grub menu thing (var_setup 0x00 0x00, as well as updated one: var_setup CpuSetup:0x00=0x00), it says its setting variables but nothing changes after reboot, sometimes with commands like (var_setup PchSetup:0x7=0x00) my laptop will reboot directly after the command (0x7 is BIOS Lock in my case).
Any information or help is gratefully appreciated.
