Yes, as I mentioned that area of BIOS is usually hidden, due to not being able to detect all card info etc.
I only updated EFI GOP, so what I sent you will only be used if you boot UEFI and disable CSM
Hi guys!
I have a card like this in my Mac Pro and I like to upgrade to latest OS. So I need to prepare the card and update it GOP to be able to see boot screens as I was told. The card is the pc version, but it’s supported in MacOS mojave I use, with no boot screens.
The problem is, I’m totally new to this. Is there somewhere a guide for newbies? Some topics found here are quite advanced and my English are not helping me a lot.
Thanks you for any help in advance.
@Axrst
Im also a Mac pro user… but you need to read a little more on the subject, you can update the GOP driver UEFI PC to the latest version but its not used in macOS boot as it uses a different kind of EFI, so it doesn’t matter.
There is such version but not around as free download, only from 3rd party sellers that do private modifications.
https://blog.greggant.com/posts/2018/05/…tml#gpuupgrades
https://forums.macrumors.com/threads/gpu…or-cmp.2174600/
Ah, thank you very much. So, I 'll have to live without boot screens…
