[Request] Tool to Customize Mobile AMD CPU Settings
Hi everyone.
I been work with chip seller at Hua Qiang Bei closely, recently we found some AMD mobile CPU (especially PRO CPUs) are locked to the mainboard it self like Intel. So suspect is something like Intel ME that doing the trick.
The scenario is something like this, we take the CPU on HP laptop mainboard & install on Acer laptop, it will not power up, just like Intel, where we need to modify the ME in bios to make it function.
Hope some one can shed some light, make repair world easier. Thanks in advance!
Edit by Fernando: Thread moved into the “BIOS Modding Tools” Category and title customized
Could it be this one?
Thank you, now i know it call PSB.
i have come under a light of AMD have implement a feature call AMD Platform Secure Boot (PSB) that will locked a CPU to that vendor or mainboard. So im thinking is there any software to explore that particular vendor’s or mainboard bios to Disable the PSB?
This “ReGESA_ASPFWTool” tool is not intended for handling AMD PSB settings, and the public version on GitHub contains several bugs, such as an x86 reset vector pointer error.
Any modifications will cause the system to fail to boot.
I do not recommend using this tool to edit any UEFI BIOS.
For PSB related stuff, I recommand psptool or, Platbox
@nsxt99 @Tris @karfel @himko9
Since the content of the 2 requests is about a similar topic and may be interesting for other AMD chipset users in the future, I have merged them and tried to give the merged thread a short, but meaningful title.
@nsxt99
If you have a better idea regarding the thread title, feel free to change it by editing your initial post.
Some additional background information about AMD’s PSB feature;
it’s essentially Intel’s “boot guard”
AMD’s “PSB” feature is managed by the “PSP(ASP)” located in the IOD (or APU). This feature is used to verify the OEM public key that is fused to the processor and cannot be disabled once enabled.
As there is no way to reverse a “fused” CPU/APU to a non-fused part.
The OEM will sign the bios’s PEI+DXE portion, and the AMD PSP ABL(SEC Stage) will verify it(PEI) evertime the system boots, if the signed content hash is not matching the signature, the PSP will refuse to boot, and halt the x86 cores in reset
However, there is a way to boot a fused processor using the original BIOS on a “third-party” motherboard, but this requires modifying the UEFI BIOS, and not all motherboards are “compatible” enough to booting to the BDS stage, (e.g. incompatible EC/SIO) and also this is considered a security issue, so I will not disclose the method here.
