[REQUEST] Unlock hidden/advanced settings ASUS TUF F15 FX506HE
Please unlock hiiden/advanced BIOS settings of my ASUS TUF F15 FX506HE(Intel Core I5 11400h)
Hey, did you find a way?
backup bios make through the pinned application: 1. cmd (as administrator); 2. cd “path to fptw file”; 3. fptw64.exe -d backup.bin (save somewhere on a flash drive); 4. FPTW64.exe -BIOS -d bios_reg_bacup.bin (modification must be carried out with this file). copy the bootx64.efi file to a flash drive. when starting the laptop (if you have FX506HE) hold down esc, select your flash drive from the list. !IMPORTANT! do all the following steps only if you have FX506HE!! enter setup_var PchSetup 0x1c 0x0; setup_var PchSetup 0x1b 0x0 → ctrl+alt+del. Than you can load mod bios without error(fptw64.exe -BIOS -f file_name.bin)
@michael33383 It actaully worked??,it unlocked all the hidden menus? It cant be that simple can it? I have the 506hc model with 11400h and 3060 so the process should be similar. Thanks for you reply!
Did a bit of reading and realized that the above steps will remove the bios lock. Now to show the hidden menus in the bios do you have to do anything else? or were the menus automatically shown for you when you do this?
This method unlocks only some hidden settings, but for this you need to sacrifice some non-hidden settings, in other words, this is a replacement of settings.
I added a link to the site, it says what needs to be done. In fact, you need to replace the visible settings with hidden ones.
