Hi everyone,
I would like modified bios for my motherboard (Z490-A-Pro) to "unhide" HPET option.
Sadly i can post links but you can find the bios file easily by just typing : MSI Z490-A-PRO on google
bios version = Version 7C75v2A
Release Date = 2021-07-01
Thank You for every answer!
hey thanks for the answer but there is no Z490 A PRO on the link you sent me, only other models, will it work if I use the wrong one ???
Sry then, ull have to do it urself then, plenty of info on forum about this subject.
So search for motherboards HPET requests/mod.
welp, thanks for the answer guess i’ll have to try
I don’t even know what guide i’m supposed to follow there is too much different words I don’t understand
