[request] x99-tf motherboard bios speaker sound modifying
Hello everyone.
I know that a motherboard beeper can produce sounds with different physical properties, and more specifically, different tones.
Also i got two versions of bios images, and i want to use the last one(“recipient” in attached files), but im not pleased with the beep sounds it has. Is there any way i can copy the beep sound defining part from one bios image to another? Or even to modify it more precisely, and create a custom tone sounds, or sequences of sounds, which would be more preferrable(the more options the better, but at first i’d like get an advice about how to get the most basic result). How do i even locate that part? Also it would be nice if someone can prompt about the way i can test the possible beep sounds without flashing/patching the bios every time.
Thanks in advance
recipient.zip (3.74 MB)
donor.zip (3.69 MB)
