[Request] Xeon E5 26XX v3 Turbo Boost Unlock on HP Z440
If we speak of new occurences, CpuMpDxe is the only place.
Here's the list.
AFAIK, uefitool does expansion automatically. In case old engine versions of the tool are unable to open this uefi, try expanding volumes manually.
I don’t think so. Although they share the same library, “IioEarlyInitialize”, the pei module is not a dependency for dxe.
It’s definitely not a version change. But I can’t tell the exact purpose of these changes. Near some of them there are mentions of bits 31, 28, 27. These minor byte changes may relate to the address space definition, where the bits are being set or reset.
Near other, there is a hex mask 0xFF00. 32 bit values of such format often used to set data lines enabled.
I don’t understand what HP updated in v165 CpuMp compared to v162.
Btw, any updates from SmokelessCpuV2?
Alright, thanks for checking! It is kind of very muddy - I think coderush was afraid of that too.
Even just putting old CpuMpDxe into the newer BIOS appears not so promising - these small byte changes are worrisome.
Also, the MC-less termination in the newer versions maybe due to the older stuff changing - such as SecCore, as you tried to address early on.
Could probably swap older CpuMpDxe into the new BIOS, keep MCs, see if it boots at all. Then try to delete MCs, check again.
This does not seem like a simple hacking exercise - just too much uncertainty …
P.S. But probably a couple of simpler things could be tried anyway - just in case they end up working …
P.P.S. v2.29 and v2.31 versions of CpuMpDxe have yet again tiny differences, and small size change too.
Alright, 2.14 does not boot without MCs. Tested.
So the key change happened between versions 1.65 and 2.14
It was sort of predictable, but good to verify!
Sorry for absence, had a loss in the family.
Micro cites macro in ifr.
@Sweet_Kitten
Well, are there any brilliant AI tools to mine for BIOS changes? Or are we not there yet? :smiley:
I don’t know any, sorry.
There is a fresh effort now - a new user @Tobim6 showed up. All 3 people who are interested in this subject can follow the developments :
Well, looks like v3 TBU unlock has been achieved on the latest BIOS! HP bios had a bug in the function in the v2.xx line of bios’es, and so it crashed without a microcode :rofl:
See the github thread for details.
Cool! So, after all, it was CpuMpDxe?
Yes, but failure was for a totally different reason - it was an HP bug! Reality is stranger than fiction …
