Hey fernando,
Hope you are keeping well my Friend ?
I want to know if you could just try to clear something up for me - so i don’t have to do a clean install on My G1 Assassin.
I am currently running the latest irst 12.7 Orom with Trim support in Raid.
It has been a while now - but do you know if The RSTe 3.8 Orom supports Trim in Raid ? I know it never used too in past versions so im curious to know if its the case.
many thx
Yes, I am fine, thanks.
AFAIK none of the RSTe drivers v3.x.x.xxxx do support the TRIM in RAID0 feature.
