Hello world,
I have a specific question about my RTX2070 MaxQ Refresh. I often read that it is possible to edit a vbios and flash it via a hardware programmer. My needs are:
Rise the TDP Limit up to 120W. (I know its risky) and then flash it via a Hardware Programmer onto the card. Or has anyone found a vbios that has like 115W TDP limit for a maxQ, or was even successful to flash it into a mobile version? I tried it my self but the card ends up in a safe mode.
MAX_Q - less parts // shit revision "more TDP only kill some GPU"
80-90W is max / slower memory
send ID / subsystem
edit/ for mobile device
need + new PSU / EC mod - or create some next problems for some notebooks brands
example "MSI EC - total power limit" - stronger GPU TDP more limit your CPU or trigger shutdown limit
some users on RTX using - shunt mod
not vbios edit "this not works here like on PASCAL"
or AFTERBURNER - voltage curve under TDP + max CORE OFFSET – good results "full safe"
