Hi,
i have modded the Sabertooth X79 with UBU 1.70 but the BIOS Flashback don´t work.
Here the Facts:
[[File:4.jpg|none|auto]]
[[File:5.jpg|none|auto]]
I´ve replaced Intel SATA Rom´s and EFI, Network Rom´s and Marvell Controller Rom´s with the newer Versions (as you can see in last Picture attached) and updated the Microcodes with MMTool 5.00.0007 (the newer one wont work on my Mainboard).
The i renamend the Bios File with UBU to SABERX79.CAP and copied it to a FAT32 formatted Pendrive.
After i shutdown my PC i connected it to the white Flashback Port and pressed the Flashback Button.
It blinks a while but not faster and then the LED turns into a solid light, but no modded Bios is flashed.
Anyone an Idea ?
Upate:
I tried AFUDOS and AFUWIN and get this Error: "secure flash function is not supported on this file"
