Samsung NP3530EC
Hi guys
Im looking for a BIOS for a Samsung NP3530EC motherboard.
Can anyone help me ?
Until now I didn’t even know, that Samsung manufactures mainboards.
Well, for their notebooks they do :slight_smile:
Problem is you find several types:
BA92-09190A => 0QA (latest 09QA)
BA92-10336A => P0
RAC
BA92-10501A => P0RAC
BA92-11488A => P0
RAP
* = version
Taken from ebay- pictures, hoping that the seller- information is correct. Each type has subtypes depending on for example graphics (but they don’t seem to have different bioses)
So what are you looking for?
If the BIOS is indifferent any really.
Thank you for your help.
Matt
BA92-09190A
http://sbuservice.samsungmobile.com/uplo…16_WIN_09QA.exe
Hi thanks, but need it in bin format for external programming. Its a dead motherboard.
Execute the file as admin on a Windows machine, don’t close the error message. You’ll find the files of the archive in %appdata%\local\temp__Samsung_update\
07.01.2018 19:03 2.621.440 09QA.rom
07.01.2018 19:03 1.648.012 09QA.rom.gz
07.01.2018 19:03 1.201 DebugAppLog.txt
07.01.2018 19:03 503.808 environment.dll
07.01.2018 19:03 221.400 environment.dll.gz
07.01.2018 19:03 2.752.512 FvRecovery.fd
07.01.2018 19:03 616.270 FvRecovery.fd.gz
07.01.2018 19:03 1.056 OemSlp20.efi
07.01.2018 19:03 526 OemSlp20.efi.gz
07.01.2018 19:03 204.800 PhlashLc_32.dll
07.01.2018 19:03 20.822 PhlashLc_32.dll.gz
07.01.2018 19:03 200.704 PhlashLc_64.dll
07.01.2018 19:03 22.594 PhlashLc_64.dll.gz
07.01.2018 19:03 40.696 PhlashNT_32.sys
07.01.2018 19:03 19.901 PhlashNT_32.sys.gz
07.01.2018 19:03 61.496 PhlashNT_64.sys
07.01.2018 19:03 25.321 PhlashNT_64.sys.gz
07.01.2018 19:03 397 PHLASH_32.INI
07.01.2018 19:03 251 PHLASH_32.INI.gz
07.01.2018 19:03 355 PHLASH_64.INI
07.01.2018 19:03 248 PHLASH_64.INI.gz
07.01.2018 19:03 15.920 SBIOSIO32.sys
07.01.2018 19:03 8.157 SBIOSIO32.sys.gz
07.01.2018 19:03 18.000 SBIOSIO64.sys
07.01.2018 19:03 8.744 SBIOSIO64.sys.gz
07.01.2018 19:03 294.912 SFlash32.exe
07.01.2018 19:03 146.112 SFlash32.exe.gz
07.01.2018 19:03 278.528 SFlash64.exe
07.01.2018 19:03 142.337 SFlash64.exe.gz
07.01.2018 19:03 8.640 Slp20.pfae
07.01.2018 19:03 3.876 Slp20.pfae.gz
07.01.2018 19:03 323.584 SWinFlash_32.exe
07.01.2018 19:03 84.587 SWinFlash_32.exe.gz
07.01.2018 19:03 307.200 SWinFlash_64.exe
07.01.2018 19:03 79.303 SWinFlash_64.exe.gz
07.01.2018 19:03 569.344 WinFlash.exe
07.01.2018 19:03 254.989 WinFlash.exe.gz
07.01.2018 19:03 760 WINFLASH.INI
07.01.2018 19:03 367 WINFLASH.INI.gz
07.01.2018 19:03 21.160 WinFlash.sys
07.01.2018 19:03 12.473 WinFlash.sys.gz
07.01.2018 19:03 23.720 WinFlash64.sys
07.01.2018 19:03 13.793 WinFlash64.sys.gz
07.01.2018 19:03 131.072 WinFlashUI.dll
07.01.2018 19:03 24.453 WinFlashUI.dll.gz
07.01.2018 19:03 130.128 WinUpV01_10.exe
07.01.2018 19:03 51.997 WinUpV01_10.exe.gz
07.01.2018 19:03 112.544 WinUpV10_ENE.exe
07.01.2018 19:03 49.593 WinUpV10_ENE.exe.gz
07.01.2018 19:03 180.224 xmllite.dll
07.01.2018 19:03 88.684 xmllite.dll.gz
