Nah. My warranty is expired anyway
Then you’re all OK, as long as your Ethernet is working (not wireless)
And as long as windows stays activated.
I don’t know if my ethernet works but I just use wifi. And windows is activated so yeah thanks a lot again ![]()
Well test it, plug in a cable and see if you can get online You may need to use that someday, for many reasons, so best to have it working just in case you need it.
Good windows is still activated. Check for updates, and reboot, then check again, if it was going to deactivate that would usually make it happen
For some reason none of my microsot services work since I upgraded to win 10. So I cant update it just says cant connect to the update service
You may need to do a clean OS install, or repair etc. Have you ran through the update troubleshooter?
Maybe one of these pages could help
https://windowsreport.com/fix-couldnt-co…update-service/
https://zillowtech.com/we-couldnt-connec…te-service.html
@Lost_N_BIOS Hi bro , I have Asus N56VZ for changed bios settings and rebooted but no video so I flashed my bios but the repair shop flashed different bios N56VB instead of N56VZ , Every thing working except NVidia GT650 , Is there any fix except flashing the right file ? If no , How can I get the right BIN file for my version because the update file is only 6MB
