I found the password and it worked, but I need more a driver called "Management Engine interface’ for windows 7. If you find it please help because it was the only file missing after updating the USB 3.0. Thanks
@madnikos no, it doesnt matter, you just have to install your drivers in test mode and you’re good to go after you reboot.
@canonkong :
Thank you for providing those magic drivers, using your digitally signed generic USB 3.0/3.1 drivers, i could install windows 7pro-64 on my Optiplex 3060/I5-8th.
I have registred in Win-Raid to thank you for your efforts and share with others my win7pro64-usb3intergated, If it’s allowed.
Regards.
@aladinsinbad
You can share it.
@sarath
what you need to install win7 on your Optitex3060 8th,
Windows 7 ISO
Ntlite
https://www.ntlite.com/download/
usb 3 drivers, provided par canonkong
No Signed modified intel IO/USB3.1 driver 32/64bit:https://yadi.sk/d/ISNYv5jV9dX5zQ
SHA256 Signed modified intel IO/USB3.1 driver 32/64bit:https://yadi.sk/d/30Ku1rUm-XdRvA
Tutoriel, provided by Fernando
[Guide] Integration of drivers into a Win7/8/10 image
@canonkong
windows 7-64BIT with USB 3.X integreted drivers
https://mega.nz/file/ErgwkQxK#Hx26DQu_n2jrfcC64AQ7JC7Vykph39PDV7EJSPlmAyM
For those who can’t find drivers for wifi - Intel® Wireless-AC 9560 officially doesn’t work on Windows lover version 10.
Just buy WiFi module like Intel 8265 ( 8000 series work with Win7 ) and replace it.
I am having a problem with win7 chipset C246 installed on the NVME hard drive, can you share with me your ISO win 7 ? Thanks a lot
Hello everyone, sorry for my English - I write through a translator.
Thanks for the driver and signature to those involved!
From 1 of the topic post downloaded the signed driver, implemented it using DISM in the Win7 iso distribution, and installed it on Gigabyte H370 using a usb drive prepared for UEFI.
But the system does not see the driver signature-it starts with an error check, you can only start the system via F8.
If I re-introduce the old V5.0.3.42 driver into the system and install it, as I understood, this problem can be avoided. BUT will there be problems with an outdated version of the driver? What are its differences?
Thanks
Hi
I’m new to the forum and facing problem while installing windows 7 on my new PC build as:
MoBo: Gigabyte Z390M
CPU: i5-9600K
SSD: WD 500GB M.2
I, somehow managed to get past the language selection dialog box cuz of PS/2 mouse (none of USB ports working), but after that I get an error (even after adding drivers through DISM) stating:
"A required CD/DVD is needed to install the missing device drivers"
On the “Browse”, I only get to see the “X” partition and no other partition is shown, meanwhile no usb ports are working (was thinking to plug usb stick with the drivers to solve).
Additionally, I tried to install windows 7 on an external HDD, but on booting the OS, Windows 7 freezes with a BSoD (0x000007b) immediately after that logo screen.
Where am I going wrong…Please guide
@NoNeEdMyRe You are going wrong with using an unmodified Windows 7 ISO, you have to integrate canonkong’s driver at the beginning of this thread or you use my mobile slipstreaming script or one of my ISOs in order to make the usb ports working. Since Windows 8 Windows uses its own xHCI drivers for every usb chips/chipset-integrated xHCI-usb ports.
After you have done that you can use WD’s driver from another usb drive or you slipstream this driver into your Windows 7 ISO too or you use M$'s official two NVMe driver hotfixes and slipstream them too.
I found a problem that Win 7 doesn’t see signed drivers, the whole reason is SHA 256 encryption. Win7 does not embed this. You need to install updates kb4474419 and kb4490628.
I have everything working on x64 Win7, Gigabyte H370. Usb 3.1 drivers latest new from 1 post of this topic.
Thanks @aladinsinbad for the ISO, it worked flawlessly, enabling the USB ports on install. I installed windows 7 but now I’m not able to find Intel graphics driver for the OS.
I found some unsigned driver for Intel UHD graphics 630, ran it on test mode, and the display turns off after windows logo screen, but I can hear the startup sound (windows loads succesfully).
My monitor is connected to the MoBo’s HDMI port, Display output is set to IGFX and internal graphics set to Enabled (cuz nvidia gpu is installed). Still the problem persists.
Any solutions…
Hi guys,
can anyone help me to find a solution about this threads? I will really appreciate any help.
A) I need to have a USB ready WIN 7 x64 (Ultimate - ita or eng) installation wich have to run on HP OMEN 15-ax012nl and so use support of all most recent chipset drivers and USB 3 drivers.
1) Wich ISO i have to use? @PatrickK @canonkong @aladinsinbad I’ve tried iso you post with WinToUsb but it don’t work.
2) WinToUsb is ok? or AOMEI partition assistant is better?
B) I also need to make a USB ready WIN 7 x64 from another system and then run into HP OMEN 15-ax012nl. This can be done by these softwares, however since OMEN use new chipset and USB 3 what i have to do? I have to instal your provided drivers in the other system then put on usb with these softwares?
I know it’s a bit complex but i don’t know no other competent people than you on these specific topics. Many thanks in advance.
@aenndd You can use any windows 7 ISO that you want, it is important that you use it correctly. Another idea from mine is that you use my mobile slipstreaming script if you already have your italian ISO and use that one for you.
I have also a normal italian iso, so what steps i should do to slipstream the iso with drivers then create a bootable win7 usb3 system? (sorry but i don’t understand the slipstreaming procedure yet)
@aenndd Did you download and read the read me first-file ?
Yes, maybe is more simple of what i think. I just have to put my ISO in same folder of your rar content and run the batch? Then after try to use the iso with WinToUsb?
@aenndd You can answer your first question by yourself if you read the mentioned file, I am annoyed a bit by you that you seem to not to have this done already.
Yes, that is the idea, but apparently it doesn’t work with that tool.
For the moment i’ve just tried to use ready to go ISO downloaded to see that this don’t work. At the moment i am preparing to try slipstream, i just ask to be sure to have understand correctly how it work. I will update here after the try ends. I also wait some help for my B) question if someone can help. Thanks again
