@StartMeUp Wow, I am surprised, thank you for your compliment on my batch file, nice to read that, especially because you write it bold. Do you have a job or a hobby that has something to do with scripting ?
Ok, my first guess is to ask you if you run the script as administrator ?
Hi PatrickK,
thanks for your reply. I do scripting for a job, mainly using PowerShell and Python.
Yes, I ran your script with admin rights - and I read your readme file
@StartMeUp Cool, that makes your complement even better for me
Good that you read it.
Did you notice the errir code hr:0x80070005 ? I suggest that you google that and see if you did some âmodsâ on you Windows installation.
I am not really into reading log files, usually I google the error code and try what works if I think I have enough information.
Typical questions/thoughts/ideas/standard questions:
What hardware are you using?
Do you have some kind of so called âantivirus softwareâ installed ? If yes I recommend to uninstall it anyways.
Did you run a sfc -scannow in cmd ?
Is your RAM ok ? How about memtest86 booted from a usb flash drive, thatâs the way I do it before I really start to play around with a computer. (You wouldnât need to run the entire test, usually, but not alway, the ram errors occur a couple second after starting the software.
.> Did you notice the errir code hr:0x80070005 ? I suggest that you google that and see if you did some âmodsâ on you Windows installation.
I already did, but until now I did not find anything useful on the web for this kind of error.
.> Typical questions/thoughts/ideas/standard questions: âŚ
I donât think answering these questions will help: read on
I made some progress: I modified your âcreate ISO.batâ to use âde_windows_7_professional_with_sp1_x64_dvd_u_676919.isoâ along with your âTreiber2.10.7zâ. Everything else in the batch file remained unchanged.
Guess what? The batch file WORKED flawlessly without any errors!
But, as we know, this same batch file (i.e. your original file) does NOT work with âen_windows_7_professional_with_sp1_x64_dvd_u_676939.isoâ and âDriverSP2.9â.
I even tried to use your batch file with a different .iso: âen_windows_7_professional_x64_dvd_x15-65805.isoâ and âDriverSP2.9â. Same errors.
Do you have any idea why the âdeâ combo works, but the âenâ combo fails?
Update:
My modified âcreate ISO.batâ using the combo âen_windows_7_professional_with_sp1_x64_dvd_u_676939.isoâ and âTreiber2.10.7zâ WORKED.
Conclusion:
There must be something wrong with âDriverSP2.9â, because the combo âen_windows_7_professional_with_sp1_x64_dvd_u_676939.isoâ and âDriverSP2.9â does NOT work.
To superyijia, Postcard88 and others.
#205 still has the links to downloadâŚ
Here are modded Intel drivers v17 from DriverStore of fresh Windows 7 Many-in-1 setup ISOs by m0nkrus - attached.
As mirror - https://www73.zippyshare.com/v/fRzWJMbw/file.html
At least they work on old DEV_ID 8C31 (no problem with USB 2.0 I wrote before) and new 9DED at first look.
Intel_v17mod.zip (3.98 MB)
The link returns "forbidden"
@bloodhand No, I wasnât able to install Windows 7 with UEFI pure UEFI. I had to enable CSM in the bios. I was only able to install Windows 7 on a gpt disk when I finished building my new PC, which has a Z390 board and an i7 9700k. Even then, it was pretty hard. I had a different thread in those forums where they helped me do it. Right now I am dual booting 7 and 10.
If you havenât already seen it, here it is.
https://www.sevenforums.com/installationâŚps-2-ports.html
That post has been updated, package is attached now.
@StartMeUp Hy, I didnât forget about you.
I copied my mobile sliptreaming script v1.1 and en_windows_7_professional_with_sp1_x64_dvd_u_676939.iso on my main machine and on of my test pcs with a new installed Windows 7 and had no problems.
Maybe it has something to do with the forceit option and/or your installation running under secure boot ?
Greetings form Switzerland.
Hello guys! Is there any chance that someone can share intel usb 3.0/3.1 driver for B360 chipset with me (Win7x64)? Seems all the links are cleared off the tread or Iâm just ocmpletely blind. Thanks in advance!
@iPetrovich You are not blind, it seems that canonkong himself has removed the links and written a reson for that which I donât understand what it means.
You can download those drivers off of my FTP download link.
@PatrickK Thank you very much! But Iâm definetely blind cause I cant find your FTP
Could you write a link?
@iPetrovich You are welcome.
Yes, because there is no one in my previous comment, you have to go back to get it, I posted it multiple times already and I donât want to post it again and again. Maybe I will write a copy-paste-comment with my link in the future, like I do with some standards-advice on other help forums, especially Facebook.
@iPetrovich
Find post #205 on 14th page with links.
Password for them in post #20.
#285 has different drivers from another author.
What is the password for links in the post #205
@nika1
In post #20.
Device ID Lists
10700K, EVGA Z490 FTW,
https://linux-hardware.org/index.php?probe=30eedadad5
10100 ASUS PRIME Z490-P
https://linux-hardware.org/index.php?probe=a3e534b4f8
@canonkong @PatrickK @aladinsinbad @NewcomerAI: thank you thank you for your hard work and generosity.
Will try to keep my questions as simple as possible.
Apologies if the answer is obvious, Iâm on a steep learning curve but determined to
do this build,stay on W7 and expand my knowledge base .
Just in the process of building my first dedicated off line system, ASUS Z390-A motherboard,
questions are;
1.Do the drivers in #205 need to be integrated into the iso provided by aladinsinbad in post #206 ?
2.If yes, do I need to install both sets of USB 3 drivers provided or only one set. If only one, which one ?
3. Once the iso is ready to go, I will need to purchase an activation code in order to complete the W7 installation.
Thanks again.
@pvmt7 You can use Windows 7 and Windows 10 without a Key, but in Windows 7, Windows will hint you on every boot and changes the desktop background to just black, which can be annoying.
I work on an english version of my SP2.9-ISOs, maybe you are the one that asked.
Thanks Patrick.
So need to purchase a key before I install 7.No problem.
Still need some help with my first 2 questions.
