Hey, can anybody mod the BIOS that i can disable / turn off (or remove) the Q-LED “Feature”? Everytime the PC boots first in BIOS, then i must manually go into bootmanager to boot windows…
i think this is because CPU light is red on the check ( but works perfect!!, also cleaned it and all things) but on this board asus put no feature to disable it like on other boards.
original BIOS Link:
https://dlcdnets.asus.com/pub/ASUS/mb/BIOS/ROG-STRIX-B650-A-GAMING-WIFI-ASUS-2214.zip?model=ROG%20STRIX%20B650-A%20GAMING%20WIFI
Sorry but this is not Q-LED culprit… this is nonsense.
I don’t even recall seeing an option to disable this feature when present in such mb models.
You have bad configuration in bios or an hw issue related to mb/cpu.
Q-LED just displays info for the user, from the hardware initialization post of the motherboard/bios, that’s it, it’s not responsible for anything more than lit leds during the UEFI initialization phases
If you don’t have any experience and this was your 1rst assembled pc…by you, i do suggest to look careful if you didn’t ofende any cpu pins or the motherboard is badly seated.
hey, no this is not my first build pc^^. i´ve checkd the CPU 3 times. no pins bend or something. i´ve cleand the cpu with isopropanol in the back but with no sucess. As i said. When i manuelly go into boot manager windows boots up and the processor has no problem with an stress test or gaming.
Only that after turn on the pc it boots into bios…thats stupid :/.
Tryd many bios options but nothing helps. Thats why i thinked the red qled light that cames after turn on is the problem.
Turn on pc > qled light is red on CPU, after 2 secons it turns off and then the BOOT qled is GREEN and the system boots into BIOS.
Can you imagine if this was to become a “regular” situation to all users???
Please give me a break will you…
Nothing more to add or to “imagine” than what was previously written.
EDIT:
Is this the same symptom after a “COLD” CMOS reset and bios defaults loaded? Are you using Corsair DDR?
yes, 2x16 gb Corsair DDR 5-5200Mhz…why?
I tryd newest BIOS, downgrade to older Version, load optimized defaults, and much more… i tryd also 1 ram, 2 ram, slot Change (actually slot 2+4 are used)
Edit ;
I tryd to record an video (pc was off since an hour or more) and now in the first Boot works
