[Solved] Dell XPS 13 9350 (2016) - long post / suspend not working
hello guys,
since a very long time I am having problems with my laptop.
It takes around 20 seconds to post and when I am trying to suspend it switches off, but after some seconds it cold boots again.
I tested it with a clean Windows install and various Linux images.
I am suspecting it’s and issue with flash chip contents or an broken NVRAM setting?
I already reflashed the latest bios from Dell and reset to factory defaults via the bootloader (poweroff, hold STRG+ESC and plug in ac), but the issues remained.
What’s interesting as well is that I can’t update the bios with this tool at all. When I run it the system reboots as it should, but it’s not flashing anything and just clean boots. I can only do it by renaming it and flash it via the bootloader.
Is there a way to reset the NVRAM and delete all unecessary stuff?
Do you think I could get it working again by flashing an edited dump from an working laptop? A friend of me has the same machine.
How can I dump and flash the whole EEPROM? Can I do it without an external device?
It’s preferable to work on ones own firmware- dump.
Regarding freshly re-configuring ME region to remove corruption see
Dell update contains a bios region, not a complete firmware image. It normally is easier to use a stock bios region and import the machine specific data from the firmware dump.
You may try to update the ME firmware to the latest 11.8 firmware, Intel tools and link to latest 11.8 ME firmware are here (if the update doen’t work it might be a sign of a corrupt ME):
Intel tools (fpt) can be used for a complete dump by software (if not restricted), too.
@lfb6
thank you for your detailed answer. I am back from testing. :smile:
I was not able to update the ME firmware with “FWUpdate”, so it’s probably really corrupt as
we assumed. I didn’t even have an ME device in the device manager or one that hasn’t any driver.
This was the error of “FWUpdate”, and “MEInfo”, which I tested too:
Error 8743: Unknown or Unsupported Platform
Cannot locate hardware platform identification
This program cannot be run on the current platform.
“FPT” told me that the ME region is locked:
Error 318: The host CPU does not have read access to the target flash area. To enable read access for this operation you must modify the descriptor settings to give host access to this region. FPT Operation Failed.
So I dumped the BIOS region to look for hidden BIOS variables to allow ME flash. For this I extracted the “Setup PE32 section” and converted it to text. I added this and the variables that I have found so far. See the attachment.
I set them in NVRAM with this tool.
I tried all possible combinations and nothing worked. “Me FW Image Re-Flash” even reset itself to it’s default value directly after I entered “reboot”.
So I digged deeper and looked for the pinmod for my motherboard and found this:
Service Mode Switch Info
I then attached a wire to the 2 pins from the left of SW1.
When I booted the system and tried FPT again the FD was still not unlocked!? See the attachment.
Do you have an idea what could be wrong or do I have to go on and buy an hardware programmer?
BTW: What can be done with “FPT -GRESET” ?
If no GRUB or jumper bridge woked, it only remains a full programing, no more miracle “software” methods here.
I would really love to see a successful example of a Service Mode Switch operation work on a Dell laptop. This is the 2nd time recently that it didn’t seem to work.
Are you using the latest CSME System Tools v11 r46 ?
Maybe you don’t have a solid 1-2 connection or it came loose?
If it does connect and works, you’re not going to see an ME device/Intel(R) Management Engine Interface in the device manager.
Can you try it again, and then take a shot at dumping your full bios with fptw64 -d backup.bin in the Flash Programming Tool\WIN64 folder?
Probably headed for a hardware programmer for that W25Q128FV bios chip. This recent topic may help.
There’s a lot that’s cyan colored (microcodes) in that bios. If you have a desire to update your MC, FPT won’t work, but it would be nice to dump the whole chip.
@ChrisM
yep, that’s the one I am using.
Never say never, but I don’t think it’s a bad connection. I even resoldered it a second time, because I thought perhaps it’s a bad connection. I also checked it with a multimeter and the connection is there.
Unfortunately that does not work, because of the locked ME region. It instantly stops and the tool doesn’t dump anything at all.
I will proceed, when I have received the hardware programmer.
Thanks for your support so far guys.
Sorry for my late reply. I was a bit busy in the last couple of weeks. :sweat_smile:
I want to thank you all for pointing me into the right directions. :heart:
I dumped the flash with an external programmer yesterday and today I injected a clean ME and NVRAM into it and it works like a charm so far.
Cold boot times decreased from 43 to 28 seconds and I was also able to flash Dell Updates again like TPM 2.0 and Thunderbolt 3.0 Firmware Update.
Can you please take a look, if I have done it right? Especially the cleaned NVRAM?
I used this post from @ChrisM as reference and extracted and replaced the first 2 “EfiFirmwareFileSystem2Guid” volumes with UEFITool.
dump.zip (6.1 MB)
fixed.zip (6.0 MB)
Hi. Way to stick with it, and a job well done.
I used UEFITool NE and extracted (“as is”) the EfiFirmwareFileSystem2Guid.vol containing the NVRAM section from the Dell update bios and your fixed.zip file, and then ran them though HxD Hex Editor, and they both compare identically, so it looks like you nailed it.
dell bios and fixed.zip (4.1 KB)
Edit1: The 2nd EfiFirmwareFileSystem2Guid.vol from your dumped bios actually indicates another NVRAM (followed by Padding). The Dell bios update does not - it simply indicates Volume free space. Both sizes are the same. But injecting both from the Dell update obviously worked.
badcaps.net has addressed your bios. See post #28’s attachment. The NVRAM structure is in that bios is identical to yours.
