[SOLVED] How do I fix FIT or insert ffs manually in Hex-Editor to load before microcode?
Hello,
I have an Intel server board which uses .cap UEFI Bios files(different from the Intel-Board thread). I was using the all core turbo exploit (I have this both as .efi as well as .ffs), by masking the existing microcode in the Bios, and then loading the hack via EFI and the actual microcode in Linux (it is important to first apply the "hack" and then a microcode of a certain age).
However, I would like to use a newer Bios that does not boot well without any microcode loaded during the initial boot. I have already found a nice combination of the new Bios and manually replaced old microcode that would work together with the turbo-hack, as long as I applied them in the correct order.
My actual FIT problems:
1. I cannot modify via UEFI Tool because the FIT-table is not correct. I know this can be fixed, but how do I calculate the correct values?
2. I tried the Phoenixtool and structure view and it kind of works, as it rearranges some data, but the resulting image does not boot.
Where and how to insert the ffs
Irrespective of the FIT problem, I could probably do it manually in HEX by replacing some unneeded DXE driver or module (not sure about the terminology, I am not familiar with this) and replacing it with the ffs.
I can look up the addresses in UEFITool, but what would I have to do? Would I replace a DXE driver or the file of an "Other Option ROM in FFS" in the terms of UBU? Would it be sufficient to to fill the original address space with zeros and insert my code at the start or would I need to modify something that it actually gets called? The code is small, but I need to make sure that it gets called as early as possible and before the microcode update.
The table below shows my POST process. Not every "microcode update" is relevant for the CPU, so for example the first line can ignored (probably ME or something, does not break the hack).
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
00:00.000 0x02 Microcode load begin
00:00.000 0x03 CRAM init begin
00:00.030 0x06 Early CPU init (Sec. phase)
00:00.040 0x06 Early CPU init (Sec. phase)
00:00.160 0xA1 Collect info such as SBSP,Boot Mode,Reset type etc
00:00.160 0xA3 Setup minimum path between SBSP & other sockets
00:00.160 0xA7 Topology discovery and route calculation
00:00.160 0xA9 Program final IO SAD settings
00:00.160 0xA8 Program final route
00:00.160 0xAA Protocol layer and other uncore settings
00:00.160 0xAE Coherency settings
00:00.160 0xAF QPI init done
00:00.170 0xB0 Detect DIMM population
00:01.850 0xB1 Set DDR4 frequency
00:01.850 0xB4 Evaluate RAS modes and save rank information
00:01.850 0xB2 Gather remaining SPD data
00:02.020 0xB3 Program registers on the memory controller level
00:02.020 0xB6 Perform the JEDEC defined init sequence
00:03.600 0xB7 Train DDR4 ranks
00:03.600 0xB8 Initialize CLTT/OLTT
00:03.610 0xB9 Hardware memory test and init
00:23.790 0xBA Execute software memory init
00:34.050 0xBB Program memory map and interleaving
00:34.050 0xBC Program RAS configuration
00:34.050 0xBF MRC done
00:34.190 0x31 Memory installed
00:34.240 0x33 CPU PEIM (Cache Init)
00:36.090 0x4F DXE IPL Started
00:38.900 0x62 DXE Setup Init
00:52.850 0x78 DXE ACPI Init
00:53.110 0x80 DXE BDS Started
00:53.120 0x81 DXE BDS connect drivers
00:53.130 0x84 DXE PCI Bus enumeration
00:53.150 0x85 DXE PCI Bus resource requested
00:54.980 0xC2 DXE Legacy Option ROM Init
01:04.400 0x89 DXE SIO Init
01:11.020 0x02 Microcode load begin
01:11.020 0x00 Clear POST Code
01:16.020 0x89 DXE SIO Init
01:16.380 0xC2 DXE Legacy Option ROM Init
01:18.260 0x02 Microcode load begin
01:18.260 0x00 Clear POST Code
02:07.910 0x89 DXE SIO Init
03:50.440 0xC7 DXE ACPI enable
03:50.440 0x00 Clear POST Code
(Do not worry about the legacy Option ROM stuff, I did not have it configured to UEFI in this log.)
@serverpanda - Upload your mod BIOS and I can fix FIT for you, or here, I made a guide
[GUIDE] Update CPU Microcode + Fix FIT Using UEFITool / Hex
This can be done easier now with UEFITool NE 55 or above, but I haven’t had time to update the guide yet. So, if this is too involved for you, upload your BIOS you need FIT fixed in and I will fix for you.
As for FFS, I don’t know what you mean, or are doing etc, to me FFS is a BIOS module, so I have no idea what you are using, doing, how or why etc - sorry.
If that is what it is to you as well, like how we would do the NVME mod, upload your FFS too with your BIOS you need FIT fixed in, and I can insert it into the BIOS for you (Usually, for NVME mod, this is after last DXE in main BIOS volume, I’d assume same for what you want, but I have no idea so it’s only a guess)
Thank you. I saw the guide before, but it did not work for me that well. (There are some differences in my Bios, no GUID for FAT, different header)
Anyway, I had a another go at it and understood how it works, rewrote the addresses and added lengths, but it is kind of worthless. On the one hand, the microcodes including architecture are detected in the structure view, but there are more problems to the whole cap.
I had another go with the Phoenixtool and now I understand:
My Bios actually includes several Bios files, that is why it was all mismatched. So first of all, I have to either stick to to pure hexediting or first unpack, use the tools and repack.
My trouble is now knowing where to insert the FFS. The good thing is that by having the four seperate Bios files, I can easily find the GUIDs to look for in Phoenixtool. I will try this way first and see if the Bios boots if I unpack and repack with Phoenix.
UPDATE:
I am marking this as solved. I am now able to alter the Bios contents via Phoenixtool. The resulting image is bootable, unless I replace a file with a wrong type. I was not able to achieve my primary goal yet, but I have to do further reading on UEFI first and then rephrase it as a new question.
UPDATE 2:
The whole idea was stupid, because the microcode is applied before the PEI.
