hey there Im using a hp g45 g5 laptop and I want to unlock advanced settings in BIOS.
so if I follow exactly what you have said will it work?
Hey! I’ve got HP 630 laptop aswell, and i’m willing to dedicate some more ram for my integrated graphics, since i upgraded my RAM to 8GB lately. My bios settings are locked, what can i do to unlock the setting for that? What other settings could be unlocked aswell? What recources should i read on that? I’ll provide any information needed about my system.
i need less vram to my igpu in a laptop g4 hp
yes thats what I want too
I need to reduce vram usage for my igpu
Can someone reupload for all three board models (3672,3674,3676) from sp53673 that already modded on advance menu and whitelist removed ?
Maybe @leolift or @theonlyjosh can share it ?
Links from @Lost_N_BIOS now are invalid.
Thank you.
Although I downloaded it once to make explanations in the duplicate thread that leolift’s request had already been responded to, I did not have his mod left.
But I have sp64612 modded.
You’re the Best my friend !!!
P.S. Russians are the best …
Here I can leave my oldest notes about the F.24 mod files (2015/16) …
Bios v.F.24 - F.23 Model 03672 Slic 2.1 Mod :
EFI / Insyde BIOS
SLIC header found in 7E374E25-8E01-4FEE-87F2-390C23C606CD_932.ROM at 0
Pubkey found in 1A1E2341-A2FB-42C7-8D17-3073D08EB21D_1235.ROM at 0
Marker found in DD6569A7-E455-4EE5-B2BA-ECDA84ACBC99_1241.ROM at 0
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at 924
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at A66
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at B80
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at C42
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_945.ROM at 3C3
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_945.ROM at E2F
OEM/Table IDs identified are:
1. INSYDEHuronRiv
2. HPQOEMSLIC-MPC
Header (INSYDEHuronRiv SLIC) (x1)
Pubkey (x1)
Marker (2.1) (HPQOEMSLIC-MPC) (x1)
7E374E25-8E01-4FEE-87F2-390C23C606CD_932.ROM Header RSA Key + Marker 2.1
Bios v.F.24 - F.23 Model 03672 Menu Tabs Unlock Mod :
Form Sets
Offset: Name:
0x122C0 Exit (0x157)
0x123F0 System Configuration (0x5A)
0x12AD0 Power (0x38D)
0x13390 Diagnostics (0x41)
0x13400 Security (0x35)
0x134F0 Advanced (0x181)
0x176F0 Main (0xCF)
0x17850 Main (0x4)
065D : 74 5B to 74 00 jz short loc_1800006BA to jz $+2
0668 : 74 50 to 74 00 jz short loc_1800006BA to jz $+2
0673 : 74 45 to 74 00 jz short loc_1800006BA to jz $+2
.text:000000018000061A loc_18000061A: ; CODE XREF: sub_180000514+E7j
.text:000000018000061A ; sub_180000514+F7j
.text:000000018000061A cmp byte ptr [rdx+49h], 0Ah
.text:000000018000061E mov r12b, r14b
.text:0000000180000621 jnb loc_1800006BA
.text:0000000180000627 cmp cs:qword_1800122B0, r14
.text:000000018000062E jl short loc_180000654
.text:0000000180000630 mov rax, cs:qword_1800A6910
.text:0000000180000637 movzx r8d, word ptr [rdi+18h]
.text:000000018000063C movzx edx, bp
.text:000000018000063F mov rcx, rsi
.text:0000000180000642 call qword ptr [rax+1F2h]
.text:0000000180000648 mov rdx, cs:qword_1800A6A20
.text:000000018000064F cmp rax, r14
.text:0000000180000652 jge short loc_180000675
.text:0000000180000654
.text:0000000180000654 loc_180000654: ; CODE XREF: sub_180000514+11Aj
.text:0000000180000654 mov eax, 181h
.text:0000000180000659 cmp [rdi+18h], ax
.text:000000018000065D jz short loc_1800006BA
.text:000000018000065F mov eax, 0CFh
.text:0000000180000664 cmp [rdi+18h], ax
.text:0000000180000668 jz short loc_1800006BA
.text:000000018000066A mov eax, 38Dh
.text:000000018000066F cmp [rdi+18h], ax
.text:0000000180000673 jz short loc_1800006BA
Bios v.F.24 - F.23 Model 03672 Remove Whitelist Mod :
91472655-50E0-4D81-9AF6-239E6F431B8C_1403.ROM StartUpMenu
Nothing
CD28DACA-BDBE-481A-90AC-625C79CF234C_1447.ROM H19BIOSLock
0396 : E8 D9 11 00 00 to 90 90 90 90 90 call sub_180001574 to nop nop nop nop nop
.text:0000000180000396 loc_180000396: ; CODE XREF: DllEntryPoint+C2j
.text:0000000180000396 ; DllEntryPoint+E4j
.text:0000000180000396 call sub_180001574 ; Eliminate
.text:000000018000039B call sub_180000914
077B : 0F 85 2D 01 00 00 to 90 90 90 90 90 90 jnz loc_1800008AE to nop nop nop nop nop nop
078F : 0F 85 19 01 00 00 to 90 90 90 90 90 90 jnz loc_1800008AE to nop nop nop nop nop nop
07A6 : 0F 85 02 01 00 00 to 90 90 90 90 90 90 jnz loc_1800008AE to nop nop nop nop nop nop
07BD : 0F 85 EB 00 00 00 to 90 90 90 90 90 90 jnz loc_1800008AE to nop nop nop nop nop nop
.text:0000000180000762 loc_180000762: ; CODE XREF: sub_1800003A8+50Fj
.text:0000000180000762 movzx ebx, dil
.text:0000000180000766 imul rbx, 0A8h
.text:000000018000076D movzx eax, word ptr [rbx+r14+1980h]
.text:0000000180000776 cmp [rsp+0C8h+var_68], ax
.text:000000018000077B jnz loc_1800008AE
.text:0000000180000781 movzx eax, word ptr [rbx+r14+1982h]
.text:000000018000078A cmp [rsp+0C8h+var_66], ax
.text:000000018000078F jnz loc_1800008AE
.text:0000000180000795 movzx eax, word ptr [rbx+r14+1986h]
.text:000000018000079E cmp [rsp+0C8h+var_3A], ax
.text:00000001800007A6 jnz loc_1800008AE
.text:00000001800007AC movzx eax, word ptr [rbx+r14+1984h]
.text:00000001800007B5 cmp [rsp+0C8h+var_3C], ax
.text:00000001800007BD jnz loc_1800008AE
.text:00000001800007C3 lea rcx, [rbx+r14+1988h]
.text:00000001800007CB lea rdx, aH19notrecord ; “H19NotRecord”
.text:00000001800007D2 call sub_18000164C
.text:00000001800007D7 test rax, rax
.text:00000001800007DA jz loc_1800008BC
Bios v.F.24 - F.23 Model 03672 RSA Mod :
86D70125-BAA3-4296-A62F-602BEBBB9081_1625.ROM PEI
86D70125-BAA3-4296-A62F-602BEBBB9081_1801.ROM PEI (Shadow)
0220 : 0F 8C CF 00 00 00 to 90 E9 CF 00 00 00 jl loc_2F5 to nop + jmp loc_2F5
Bios v.F.24 - F.23 Model 03674 Slic 2.1 Mod :
EFI / Insyde BIOS
SLIC header found in 7E374E25-8E01-4FEE-87F2-390C23C606CD_960.ROM at 0
Pubkey found in 1A1E2341-A2FB-42C7-8D17-3073D08EB21D_1146.ROM at 0
Marker found in DD6569A7-E455-4EE5-B2BA-ECDA84ACBC99_1152.ROM at 0
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_65.ROM at 8F4
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_65.ROM at 99C
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_65.ROM at ADE
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_65.ROM at B02
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_974.ROM at 37F
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_974.ROM at 3F6
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_974.ROM at 11FB
1. INSYDECalpella
2. HPQOEMSLIC-MPC
Header (INSYDECalpella SLIC) (x1)
Pubkey (x1)
7E374E25-8E01-4FEE-87F2-390C23C606CD_960.ROM Header RSA Key + Marker 2.1
Bios v.F.24 - F.23 Model 03674 Menu Tabs Unlock Mod :
Form Sets
Offset: Name:
0x80350 Main (0xE8)
0x80600 Exit (0x384)
0x80710 System Configuration (0x59)
0x80DF0 Power (0x301)
0x81330 Security (0x34)
0x81420 Advanced (0xF5)
0x852B0 Diagnostics (0x40)
0651 : 74 50 to 74 00 jz short loc_1800006A3 to jz $+2
065C : 74 45 to 74 00 jz short loc_1800006A3 to jz $+2
.text:000000018000060E loc_18000060E: ; CODE XREF: sub_180000508+E7j
.text:000000018000060E ; sub_180000508+F7j
.text:000000018000060E cmp byte ptr [rdx+49h], 0Ah
.text:0000000180000612 mov r12b, r14b
.text:0000000180000615 jnb loc_1800006A3
.text:000000018000061B cmp cs:qword_18000EAD8, r14
.text:0000000180000622 jl short loc_180000648
.text:0000000180000624 mov rax, cs:qword_180085690
.text:000000018000062B movzx r8d, word ptr [rdi+18h]
.text:0000000180000630 movzx edx, bp
.text:0000000180000633 mov rcx, rsi
.text:0000000180000636 call qword ptr [rax+1F2h]
.text:000000018000063C mov rdx, cs:qword_180085730
.text:0000000180000643 cmp rax, r14
.text:0000000180000646 jge short loc_18000065E
.text:0000000180000648 loc_180000648: ; CODE XREF: sub_180000508+11Aj
.text:0000000180000648 mov eax, 0F5h
.text:000000018000064D cmp [rdi+18h], ax
.text:0000000180000651 jz short loc_1800006A3
.text:0000000180000653 mov eax, 301h
.text:0000000180000658 cmp [rdi+18h], ax
.text:000000018000065C jz short loc_1800006A3
Bios v.F.24 - F.23 Model 03674 Remove Whitelist Mod :
91472655-50E0-4D81-9AF6-239E6F431B8C_1288.ROM StartUpMenu
Nothing
CD28DACA-BDBE-481A-90AC-625C79CF234C_1334.ROM H19BIOSLock
Bios v.F.24 - F.23 Model 03674 RSA Mod :
86D70125-BAA3-4296-A62F-602BEBBB9081_1840.ROM PEI
86D70125-BAA3-4296-A62F-602BEBBB9081_1663.ROM PEI (Shadow)
Bios v.F.24 - F.23 Model 03676 Slic 2.1 Mod :
EFI / Insyde BIOS
SLIC header found in 7E374E25-8E01-4FEE-87F2-390C23C606CD_869.ROM at 0
Pubkey found in 1A1E2341-A2FB-42C7-8D17-3073D08EB21D_1029.ROM at 0
Marker found in DD6569A7-E455-4EE5-B2BA-ECDA84ACBC99_1035.ROM at 0
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at 8F4
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at A1E
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at B62
’SLIC’ string found in 85674556-04B3-4151-8612-53C628835F34_50.ROM at C09
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_880.ROM at 3A0
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_880.ROM at 110B
’SLIC’ string found in AFC04099-0D39-405D-BE46-846F08C51A31_880.ROM at 11CB
1. INSYDENapa
2. HPQOEMSLIC-MPC
Header (INSYDENapa SLIC) (x1)
Pubkey (x1)
7E374E25-8E01-4FEE-87F2-390C23C606CD_869.ROM Header RSA Key + Marker 2.1
Bios v.F.24 - F.23 Model 03676 Menu Tabs Unlock Mod :
Form Sets
Offset: Name:
0x73450 Main (0xE9)
0x735D0 Exit (0x365)
0x73700 System Configuration (0x5B)
0x73DD0 Power (0x2E5)
0x746D0 Security (0x36)
0x747C0 Advanced (0xFB)
0x77B10 Main (0x4)
0x77DD0 Diagnostics (0x42)
067B : 74 55 to 74 00 jz short loc_1800006D2 to jz $+2
0685 : 74 4B to 74 00 jz short loc_1800006D2 to jz $+2
068F : 74 41 to 74 00 jz short loc_1800006D2 to jz $+2
.text:0000000180000666 loc_180000666: ; CODE XREF: sub_180000564+E7j
.text:0000000180000666 ; sub_180000564+F7j
.text:0000000180000666 cmp byte ptr [rdx+49h], 0Ah
.text:000000018000066A mov r12b, r14b
.text:000000018000066D jnb short loc_1800006D2
.text:000000018000066F movzx ecx, word ptr [rdi+18h]
.text:0000000180000673 mov eax, 0FBh
.text:0000000180000678 cmp cx, ax
.text:000000018000067B jz short loc_1800006D2
.text:000000018000067D mov eax, 0E9h
.text:0000000180000682 cmp cx, ax
.text:0000000180000685 jz short loc_1800006D2
.text:0000000180000687 mov eax, 2E5h
.text:000000018000068C cmp cx, ax
.text:000000018000068F jz short loc_1800006D2
.text:0000000180000691 movzx eax, byte ptr [rdx+49h]
.text:0000000180000695 add rax, rax
.text:0000000180000698 mov [rdx+rax*8+54h], cx
.text:000000018000069D mov rcx, cs:qword_180078298
Bios v.F.24 - F.23 Model 03676 Remove Whitelist Mod :
91472655-50E0-4D81-9AF6-239E6F431B8C_1164.ROM StartUpMenu
Nothing
CD28DACA-BDBE-481A-90AC-625C79CF234C_1210.ROM H19BIOSLock
0376 : E8 2D 11 00 00 to 90 90 90 90 90 call sub_1800014A8 to nop nop nop nop nop
.text:0000000180000376 loc_180000376: ; CODE XREF: DllEntryPoint+C2j
.text:0000000180000376 ; DllEntryPoint+E4j
.text:0000000180000376 call sub_1800014A8 ; Eliminate
.text:000000018000037B call sub_1800008F4
075B : 0F 85 2D 01 00 00 to 90 90 90 90 90 90 jnz loc_18000088E to nop nop nop nop nop nop
076F : 0F 85 19 01 00 00 to 90 90 90 90 90 90 jnz loc_18000088E to nop nop nop nop nop nop
0786 : 0F 85 02 01 00 00 to 90 90 90 90 90 90 jnz loc_18000088E to nop nop nop nop nop nop
079D : 0F 85 EB 00 00 00 to 90 90 90 90 90 90 jnz loc_18000088E to nop nop nop nop nop nop
.text:0000000180000742 loc_180000742: ; CODE XREF: sub_180000388+50Fj
.text:0000000180000742 movzx ebx, dil
.text:0000000180000746 imul rbx, 0A8h
.text:000000018000074D movzx eax, word ptr [rbx+r14+1860h]
.text:0000000180000756 cmp [rsp+0C8h+var_68], ax
.text:000000018000075B jnz loc_18000088E
.text:0000000180000761 movzx eax, word ptr [rbx+r14+1862h]
.text:000000018000076A cmp [rsp+0C8h+var_66], ax
.text:000000018000076F jnz loc_18000088E
.text:0000000180000775 movzx eax, word ptr [rbx+r14+1866h]
.text:000000018000077E cmp [rsp+0C8h+var_3A], ax
.text:0000000180000786 jnz loc_18000088E
.text:000000018000078C movzx eax, word ptr [rbx+r14+1864h]
.text:0000000180000795 cmp [rsp+0C8h+var_3C], ax
.text:000000018000079D jnz loc_18000088E
.text:00000001800007A3 lea rcx, [rbx+r14+1868h]
.text:00000001800007AB lea rdx, aH19notrecord ; “H19NotRecord”
.text:00000001800007B2 call sub_180001580
.text:00000001800007B7 test rax, rax
.text:00000001800007BA jz loc_18000089C
Bios v.F.24 - F.23 Model 03676 RSA Mod :
86D70125-BAA3-4296-A62F-602BEBBB9081_1347.ROM PEI
86D70125-BAA3-4296-A62F-602BEBBB9081_1480.ROM PEI (Shadow)
Donovan RSA Mod :
86D70125-BAA3-4296-A62F-602BEBBB9081_1407.ROM PEI
86D70125-BAA3-4296-A62F-602BEBBB9081_1585.ROM PEI (Shadow)
CodeRush RSA Mod :
62EB36E4-61DC-4861-9451-45AB2D3EFABA_1208.ROM NO
02F1 : 85 C0 to 31 C0 test eax, eax to xor eax, eax
If I remeber yet I didn’t check the RSA Lock bypass at that time, but now all is possible and also we know how to do …
I hope that these will be helpfull for you and for Lost_N_BIOS who has spent his life helping us all, many thanks firend !!!
Thank for your share @Sweet_Kitten
I’m surprised you already create mod for latest bios.
FYI, after running InsydeFlash then klik start, my notebook suddenly hang and flashing failed before erase/write process.
I have to unplugged my battery to boot normally again.
Any consideration for using your mod bios?
thank you for reveal it, is it using IDA ?
This happens when the BIOS is not for your notebook, but it is pointless in your case, because the BIOS is exactly for the HP 630.
For a faster response of the flash tool, I disabled the platform check by bios in the mod. It usually works, it seems like I shouldn’t have done it this time. I reverted the changes, but the flashing will start slowly.
The mod is available at the same link!
To "uwyref" , yes IDA Pro 6.3/6.5 (at that time), now 7.5.
To "Sweet Kitten" , You are fantastic, remade iscflash.4.1.6.1.dll patch and Setuputility, (RSA thanks to CodeRush and Donovan6k) and You removed comletly … Super ![]()
Thank you.
But after redownload your mod and apply it , found that problem still persist.
I have saw that it’s different approch to patch the dll file, so if do You want try this one …
We will wait the “Sweet Kitten” response, but meanwhile You have a chance to try :
https://www.mediafire.com/file/xysaj7bld…1.6.1.rar/file
Let us know
Regards
P.S. unpack rename as original and replace into mod servicepack folder, then run againf InsydeFlash
I’m giving a look to the code and for me this it’s enough to make the mod …
BDMaster Bios F.39 model 0672 SetupUtility Mod :
.text:0000000180000632 loc_180000632: ; CODE XREF: sub_1800004F8+113↑j
.text:0000000180000632 mov eax, 181h >> Advanced (0x181 from string package 0x0)
.text:0000000180000637 cmp [rdi+18h], ax
.text:000000018000063B jz short loc_180000699
.text:000000018000063D mov eax, 0CFh ; ‘Ï’ >> Main (0xCF from string package 0x0)
.text:0000000180000642 cmp [rdi+18h], ax
.text:0000000180000646 jz short loc_180000699
.text:0000000180000648 mov eax, 38Dh >> Power (0x38D from string package 0x0)
.text:0000000180000651 jz short loc_180000699
063B : 74 5C to 74 00 0x12830 Advanced (0x181 from string package 0x0)
0646 : 74 51 to 74 00 0x16A30 Main (0xCF from string package 0x0)
0651 : 74 46 to 74 00 0x11E10 Power (0x38D from string package 0x0)
Regards
If so, then I have no clue what is going on.
But referring to the history of posts with LOST_N_BIOS’s mods, he might not have used the MultiFD function because he made mods for each platform separately. Perhaps this is the problem, and I shouldn’t have touched the .ini files either.
Also, @uwyref , does the original update from the support site work?
for about 6 hours ago i also have a thought about doing something on .ini files.
I try to get .ini from stock bios and successfully flashed.
After auto reboot my bios become stuck and have blinking A on keyboard
I have to debrick by HP_TOOLS from stock F.38 sp60723 (official hp site) using Phoenixtool.
Then i try upgrade to stock F.39 sp64612, it’s smothly applied.
I already doing this and still, my notebook suddenly hung after clicking Insydeflash start button
Can we have your mod version @BDMaster ?
This indicates that the BIOS was successfully flashed, but the RSA check patch for this BIOS does not work. And it also suggests that I still do not fully understand how things are with the methods of bypassing it. Now we at least know that the platform of your device is 3672 or 3674.
Let’s follow the same way of using the BIOS version before implementing this protection. Flash sp53673 modded as you already did it somehow with sp64612
Okay, after checking from entering bios info and many windows applications, it saying board type is 3673.
I confirmed this version (F.19.mod) successfully flashed, no issue when downgrade from F.39(stock) to your F.19(mod).
However ,I didn’t do .ini files replacement this time.
For hanging behaviour after clicking start i found that ‘unplug and plug’ (while AC powered) battery resolve it, keyboard and touchpad become functional again to click OK button then erase/write process starting until autorestart.
Entering F.19 mod bios, showing all mod are activated.
I use the same method ‘unplug and plug’ battery on your F.39 mod, didn’t succeed after all.
Maybe you can create mod on fully multi-FD F.39 @Sweet_Kitten
Thank you.
wow,I considered lost the advances for the bios insyde hp, I have an old laptop g4 2072la with bio insyde f 2nd revision dated from 2016 with this I can set the vram memory of my integrated gpu in 512mb?
did you mean gpu aperture size?
may be you will find 256MB to 512MB to choice
