Hi,
I have a specific problem with NVMe boot on a Lattepanda Alpha 864s.
For some reason the onboard eMMC where Win10 OS is installed is corrupt. The complete Users folder is inaccessible. It’s a eMMC error, because the controller locked it to read only. No recovery, no new installation is possible.
Ok, then simply install a NVMe SSD and forget that eMMC thing.
Installation is a success, but BIOS can´t boot from it. It is not selectable as primary boot drive. I checked some things, booted into (BIOS) EFI shell. Everything is fine there, AMI NVMe Bus Driver is present, I see the drive, I can mount it and I can see every file.
At some point BIOS prevents listing of that drive in the bootlist.
Is it possible to fix that?
I made some bios mods in the past, but for this issue a have no idea at the moment.
It is a known problem in the Lattepanda forums, but there is no support, no BIOS updates, nothing. So I have to do it on my own.
Thanks in advance
CDJQ-BS-7-S70KR300-KF65A-101-M.zip (4.47 MB)
