anyone pls help me modifying this Qfan control so it can run below 60%
P8Z77-M-ASUS-2105.zip (4.3 MB)
I tried to look for a solution to this before but no one seemed to know or care, in the end what I think I did was tie all of my pwm signal from the fans to the cpu header which allowed it to be set to 0. (at least on Asus P8P67 Rev 3.1)
Basically you cut the pwm wire (or make some adapter) on all your fans tie them all together and connect the wire to the cpu pwm.
Maybe speedfan allows you to set 0 but I didn’t try when I had my p67 board
appreciate the answer ![]()
sadly my cpu pwm only allow to 20%
i think that is the best i can do
thank you sir
