Hello, can’t find answer for simple question.
I want to enable Intel AMT for my motherboard using clean intel me dump.
The guide Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization says to work with the spi dumped bios.
Can I use instead the bios downloaded from the manufacturer website?
Only difference is Configured instead of Initialized in File System State.
Me analyser info about downloaded bios from manufactured website:
Maybe, if the vendor has full firmware images in his updates… But by using an outimage file created from a stock firmware you might loose your machine specific data.
What do you mean under “machine specific data”?
Bios downloaded from manufacturer website also has Configured state.
So if I flash it - I will also loose my machine specific data, right?
My plan is:
Flash bios downloaded from website with manufacturer utility.
Rebuild same bios with clean ME Region with fit.exe
