hi guy its possible to unlock ssd with security password enabled ?
i try hdparm but i have errors
any ideas ?
Since I don’t have any experience about how to unlock an SSD, which has been protected by a security password, I cannot help you.
deattach and than reattach the power cable from the ssd
(if hotplug is enabled in bios you could execute it while running your system)
I removed and installed but nothing happens … unfortunately I think a password is set in the bootloader of my ssd
Think you should contact Toshiba technical support.
