[Tool AMIBCB] Unlock CBS/PBS Swapping GUID Method on ASUS
It may be a little bit different from device to device, but it should have a similar structure. to change the name submenu, you can easily do this in AMIBCP.
Here is a sample taken from an ASUS TP420IA device.
Setup - Ref Submenu
0F 21 7E 01 7E 01 16 00 00 00 FF FF 00 01 00 00 00 2A EC B6 4F 01 AC C7 4E AD 06 21 AD D5 BD 46 1F ← IDE Configuration
0F 21 9D 02 9D 02 18 00 00 00 FF FF 00 01 00 00 00 BE C6 CD 97 92 77 82 47 BA 6D E6 E3 BB 56 AC D8 ← Option ROM Dispatch Policy
Setup - Ref Submenu - Edit
0F 21 7E 01 7E 01 16 00 00 00 FF FF 00 0B 00 00 00 59 B9 63 B8 C6 0E 33 40 99 C1 8F D8 9F 04 02 22 ← AMD PBS Option
0F 21 9D 02 9D 02 18 00 00 00 FF FF 00 00 70 00 00 E3 35 45 B0 04 30 46 49 9E B7 14 94 28 98 30 53 ← AMD CBS
AMITSE - External GUID List
2A EC B6 4F 01 AC C7 4E AD 06 21 AD D5 BD 46 1F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← IDE Configuration
4A 10 59 7B 0D C0 58 41 87 FF F0 4D 63 96 A9 15 10 27 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← Setup
BE C6 CD 97 92 77 82 47 BA 6D E6 E3 BB 56 AC D8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← Option ROM Dispatch Policy
04 F3 A9 AC E2 21 52 48 98 75 7F F4 88 1D 67 A5 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← PCI Subsystem Settings
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← Empty
AMITSE - External GUID List - Edit
59 B9 63 B8 C6 0E 33 40 99 C1 8F D8 9F 04 02 22 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← AMD PBS
E3 35 45 B0 04 30 46 49 9E B7 14 94 28 98 30 53 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ← AMD CBS
setupdata - GUID + 53 00 65 00 74 00 75 00 70
2A EC B6 4F 01 AC C7 4E AD 06 21 AD D5 BD 46 1F 53 00 65 00 74 00 75 00 70 ← IDE Configuration
BE C6 CD 97 92 77 82 47 BA 6D E6 E3 BB 56 AC D8 53 00 65 00 74 00 75 00 70 ← Option ROM Dispatch Policy
setupdata - GUID + 53 00 65 00 74 00 75 00 70 - Edit
59 B9 63 B8 C6 0E 33 40 99 C1 8F D8 9F 04 02 22 53 00 65 00 74 00 75 00 70 ← AMD PBS
E3 35 45 B0 04 30 46 49 9E B7 14 94 28 98 30 53 53 00 65 00 74 00 75 00 70 ← AMD CBS
setupdata - Footer GUID
4A 10 59 7B 0D C0 58 41 87 FF F0 4D 63 96 A9 15 01 00 00 00 ← Setup
2A EC B6 4F 01 AC C7 4E AD 06 21 AD D5 BD 46 1F 88 00 00 00 ← IDE Configuration
BE C6 CD 97 92 77 82 47 BA 6D E6 E3 BB 56 AC D8 99 00 00 00 ← Option ROM Dispatch Policy
04 F3 A9 AC E2 21 52 48 98 75 7F F4 88 1D 67 A5 88 00 00 00 ← PCI Subsystem Settings
2E 20 E1 80 97 26 64 42 9C C9 80 76 2C 3E 58 63 40 00 00 00 ← Recovery
setupdata - Footer GUID - Edit
59 B9 63 B8 C6 0E 33 40 99 C1 8F D8 9F 04 02 22 88 00 00 00 ← AMD PBS
E3 35 45 B0 04 30 46 49 9E B7 14 94 28 98 30 53 99 00 00 00 ← AMD CBS
@karfel
Since the Forum Category β€œBIOS Modding/Flashing Tools” didn’t exist, when you started this interesting thread, I have moved it there and customized its title.
I hope, that you agree with my action. Otherwise you can easily change everything by editing your initial post.
I’d prefer to delete this thread. It turns out the method is pretty much the same for other devices with the Aptio 5 platform, and I went a little overdoing it in this thread lol. I’m planning to make a guide for adding CBS, PBS, and Aod in the future. The only problem is that the Aod (AMD Overclocking) menu is still being tested by other forum members here and still fail (⁠q⁠ノ⁠ω⁠\⁠q⁠).
@karfel
It would be fine, if you could write a guide, which is usable for a great variety of systems with an AMI Aptio V BIOS.
Once it is ready and published, you delete this thread yourself.
Thanks again!
