Let me know how my edit goes w/ block/SMU re-arranging, if that works, then maybe I can add some manual edit info here for others to use in such cases Or you can use my notes and explain maybe? I’m messy, at making out notes, and explaining, so maybe cleaner if you explain Plus, I am Intel user and know nothing about any of this AMD stuff
* About the rearrange method I did, that could also be done as 2, 3, 1 too, instead of 2, 1, 3 (original 1, 2, 3 of of course) Update order in settings.json accordingly afterwards, if using it for any post-manual updates
LeagueRaINi needs to update his program
Also, in the Chiphell thread I linked you to, or maybe the OCN thread you linked me to? >> I see it’s possible that some SMU may not work with some BIOS, some AGESA, or some CPU’s So if/when edits/updates fail, you may never know if it’s due to this or just the edit method in general (very non-ideal situation when you hit a failure )
@Ruin - You’re welcome!! So, did it work, all booting OK, and seems to be functioning properly? And, as I asked in PM, can you AMD users see while in windows, what versions of these “SMU” are currently in use? So you can confirm the changed updates are actually being loaded and used?
@RaINi@LeagueRaINi - Seems neither is a user name here Maybe you can contact him at github, or at Chiphell?
@Ruin - Bummer Sorry this method does not work, but at least now we know, and it’s probably a good thing, because if you always had to do it that way it would be a pain for many users.
So, @Stilt wont answer you, or give info on how he did the edit either? I assumed he used similar manual method, but your test shows this probably is not the case and he used another method or edited the tool above to work better That or I missed something else there that needs adjusted too,other than those two tables I mentioned? * Actually! I just looked at your downgrade vs original, and those tables are NOT adjusted for size (offsets always same in your downgrade vs OG, but size is not, and those were not changed in these tables as they should be) Did you test your downgrade version yet? If not, test it now, if it’s OK, maybe I just need to edit for you once more and change the sizes in the tables back to OG size values
Did you read through that Chiphell thread I sent you, maybe some info there? I never did translate it, but I will now and see if I can find anymore info about this from there. * Edit - Maybe issue due to what they discuss in post #96, and that SMU versions not compatible with your board?
