[Tool] UniversalAMDFormBrowser
Hi im having some issues with booting in the usb. I turned the secure boot off, enter the boot menu, select the usb, and then some console messages appear on the left of my screen, and then its just black screen. I have Lenovo ThinkPad x13 gen 1 with amd ryzen pro 4650u if that can help…
For my laptop hp elitbook 745 g5 Ryzen 3 pro 2300u 16gb ram. options AMD CBS not showing dere is nothing except network settings end i want to change the vram from 1 to 4 gb or 3 gb , universal amd form browser not work for me , no amd CBS problem
My wife got me a AX16PRO (AMD Ryzen 7 5825U with Radeon Graphics) for Christmas, and I tried to go in and up the VRAM, got the same error you did when trying to save. No combination of choices would save. No other settings would save. I’m not a programmer, but I can usually install a fix if I can find it. Anybody got a fix for this I can follow?
Thinkpad E14g2 amd 4500u not working, just black screen on loading
Tried oldest possible bios version, same
Tested on latest gen Thinkpad with amd 7730U and seems to be working fine…
Any ideas on getting this to work for my 4500u?
Bro,I am a rookie in the bios or efi program,so i hard to apprehend what you talk about and do this with your guidance.I have the same problem like this article, but my laptop is xgm core 15,e21.I hope you submit the completed
efi file to github that i could tackle this annoyance,expect it,and sorry for my disturbance
Hi, I have HP elitebook 845 g7 ryzen pro 5 4650u. as previous users faced and experienced, the device manager option was empty and i can’t access AMD CBS options when I used the tool. I tried the "AMITSE.efi” solution provided by Sweet_Kitten but it didn’t work. Is there any way to know my device situation? My BIOS Manufacturer / Type: InsydeH2O, ROM Family: S77, BIOS Version: 01.22.00.
Gemini told me that my bios is not AMI and so AMITSE.EFI is normal to not work with me. I would appreaciate any help to adress what can i do to be able to get to these bios settings.
my goal is to change the ulck and flck to 1600mhz which is the ideal frequency when i have 8x2 3200mhz ram. and to change the buffer size to 4gb. is that even possible or am i wasting my time?
Hello.
Although, I don’t remember a solution which involves this file, If the browser loads for you without additional files, you don’t need to run anything else in advance to UiApp. It won’t add more settings.
Elitebook owners are rare visitors of the requests sub-forum, so idk too. And we’ll never know if you not going to create a request.
Nevermind, I just checked the bios update file and there’s nothing to unlock. HP included only 4 pages you can access by default, no FLCK or ULCK.
Cross-posting here for visibility (open-source reimplementation):
Thanks again @AARCH64_EL3 !!!
Hi everyone. I’d like to ask about the difference between “continue” and “reset” in UAFB. I’m trying to unlock the hidden Curve Optimizer option in the BIOS of my HP laptop. I first modified a value using RU.EFI, then configured Curve Optimizer in UAFB. After that, should I choose “continue” or “reset”? The value I modified with RU.EFI reverts to the original one when I reboot and enter RU.EFI again, so I have to modify it again to bring back the Curve Optimizer option—but by then, my previous Curve Optimizer settings are all gone.
I tried this on my ASRock X870E Taichi, and it opened, but when I tried to change anything under Setup or AMD stuff, it said it failed to save changes to the Trusted Computing page, and said something about a mismatch between setup and value, and then after it forced me to reboot to apply changes, the tool won’t start anymore.
ASSERT [UiApp] /home/pc/edk2/edk2/MdeModulePkg/Library/BootMaintenanceManagerUiLib/BootOption.c(242): CR has Bad Signature
