Unlock bios settings to adjust memory timings for an HP laptop
I have an HP 15-dw3021nia laptop
I5 11th gen 4 cores 8 threads 4.2 GHz
4+8 GB DDR4 3200
I want to unlock memory options to adjust timings because they are very bad with default settings getting very poor bandwidth killing my laptop performance.
I used UEFI tools to find the section that I need to look into it. I extracted it, but Universal UEFI extractor couldn’t recognize the section protocol as UEFI. it shows “Unknown”
0899F.zip (6.8 MB)
https://www.reddit.com/r/Hewlett_Packard/comments/o1zxuv/howto_unlock_undervolting_change_timings_on_hp/ follow Part 2 it works for most HP laptops. Don’t follow Part 1 as it’s for a different laptop and you could change unwanted settings
Also keep in mind that if you mess up you will have to do a CMOS reset.
Thank you, but I mentioned that Universal IFR extractor already does not work.
I appreciate your help :blush:
