PC: Asus BM6630 Desktop PC
network card: Intel 82579V
Asus replied to my support request as follows: “in relation to the problem highlighted, please check that the” power on By pci express "option is enabled in the Bios and that UEFI ADVANCED - APM - ERP READY is set to DISABLED"
I have enabled Power On By PCIE while ERP READY is not available, (the support says that if not available, wake on lan should already work in this mode).
Unfortunately, these settings didn’t work!
Later I noticed that in CPU Configuration section, there are the entries:
CPU C1E
CPU C3 Report
CPU C6 Report
Is it possible that these entries are involved in the matter?
Could someone suggest me the correct bios settings to make wake on lan work?
