WiFi6 card: code 10 error
Hello,
I’m describing my problem with AX200 and AX210 mini PCIe chinese version cards:
My computer: Fujitsu AH531/GFO (i7-2820QM - HM65 chipset - Windows 10 Pro 20H2 x64) I was using Intel Centrino Wireless-N 1030 and nextly Intel Dual Band Wireless-AC 7260 in this laptop.
I placed both this cards on my laptop. Bluetooth works perfectly but WiFi shows code error 10:
I installed newest drivers and tested many drivers:
I upgraded chispet driver from version 1.1.1.45 to 1.1.3.1. Problem still happend.
The BIOS is the newest - 1.24. I updated all drivers - Fujitsu BIOS driver too. Problem still happend.
So I put this cards to Dell Latitude E6520 (QM67 chipset) with the same drivers like in Fujitsu. Cards works perfectly on Dell! No error / code 10!
Nextly I putted HDD from Dell (where everything works good) to Fujitsu. And… code 10 for AX210 card happend in Fujitsu with HDD(system) from Dell.
Events of card:
1
2
3
4
5
6
7
8
Device PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&21309e35&0&00E0 was not migrated due to partial or ambiguous match.
Last Device Instance Id: {5d624f94-8850-40c3-a3fa-a4fd2080baf3}\vwifimp_sap\5&3420cd70&0&11
Class Guid: {4d36e972-e325-11ce-bfc1-08002be10318}
Location Path:
Migration Rank: 0xF000FFFFFFFFF122
Present: true
Status: 0xC0000719
1
2
3
4
5
6
7
8
9
10
11
12
13
Device PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&21309e35&0&00E0 was configured.
Driver Name: oem9.inf
Driver Date: 04/19/2021
Driver Version: 22.50.0.7
Driver Provider: Intel
Driver Section: Install_GEN_SLR_TyP_210_AX_6G_2x2_WinT
Driver Rank: 0xFF0001
Matching Device Id: PCI\VEN_8086&DEV_2725&SUBSYS_00248086
Outranked Drivers: oem87.inf:PCI\VEN_8086&DEV_2725&SUBSYS_00248086:00FF0001 oem71.inf:PCI\VEN_8086&DEV_2725&SUBSYS_00248086:00FF0001 oem79.inf:PCI\VEN_8086&DEV_2725&SUBSYS_00248086:00FF0001 oem188.inf:PCI\VEN_8086&DEV_2725&SUBSYS_00248086:00FF0001
Device Updated: true
Parent Device: PCI\VEN_8086&DEV_1C10&SUBSYS_161010CF&REV_B5\3&11583659&0&E0
1
2
3
4
5
6
7
8
9
Device PCI\VEN_8086&DEV_2725&SUBSYS_00248086&REV_1A\4&21309e35&0&00E0 had a problem starting.
Service: Netwtw10
Lower Filters:
Upper Filters: vwifibus
Problem: 0xA
Problem Status: 0xC0000001
Anyone know what I have to do to use WiFi6 card on Fujitsu AH531/GFO?
Best regards.
My guess is that Fujitsu has a Whitelist in the BIOS implemented which devices are approved from Fujitsu to work in that notebook.
2nd guess, the notebook is too old to recognize newer PCI-E cards
Cheers
Fujitsu don’t have whitelist. This notebook was only one WiFi card: N-1030. So probably is too old… :frowning:
Reset the bios without the wifi cards and then remove battery and power for few seconds and then retry after you put one by one card in the laptop.
