Hello, I want to inform you that the BIOS has several errors when installing Win 10
it crashes and gives blue screens
I use it with a PCEI 1x to NVME adapter
I also installed it with a rizer and it gives the same problem
Is there a possibility of correcting the errors
My motherboard is an Asrock H61 VG3
@js07546
Since it seems, that your problems to get Win10 installed have nothing to do with the topic of your previously started thread, I have moved this post into the “Windows 10” Forum Category by starting a new thread.
Questions:
- Did you follow “Step 4 - Installation of Win10/11” of >this< Guide?
- Which BSOD error message/Code did you get?
- What is a “rizer”?
Good luck!
