Wrong BIOS flash
Hi friends
my friends flash wrong bios model on laptop. laptop model is ASUS K53SM and his flash K53SV BIOS wrongly on laptop now usb3.0 and wifi not work any way to flash K53SM original bios ? wich program can do it ?
sorry for bad english
@ ErfanDJ:
Have you or your friend already tried to reflash the "normal" (correct) BIOS the normal way?
If the original BIOS cannot be flashed the usual way, you may look into >this< thread.
thanks for answer
I dont have Raspberry Pi can I flash using Intel FPT tools ?
I doubt, that this tool will be usable for ASUS laptops (look >here<). If you want to be sure, you should ask CodeRush.
