Hi,
i have a Z590 AORUS ELITE AX (rev. 1.0) and i wanna disable virtualization.
can you help please to build a custom bios ?
Regards.
Hi,
Regards.
Use the UEFI Editor
Hello, thank you @MeatWar for guiding me
I was able to mod the bios and disable the feature that original bios forced to use,
unfortunately i was not able to show the menu in the BIOS.
Maybe i gonna spend more time later.
Anyway was helpful the guide.
+Reps
Regards.
